Siebel System Administration Guide > Configuring the Browser for Siebel Web Clients > High-Interactivity Deployment—Java Requirements > Uninstalling Java ControlsIf any Java controls that have been downloaded to a user's machine are no longer needed, you can uninstall them by deleting them from the Temporary Internet Files folder. This folder is located in a folder similar to the following:
where username represents the Microsoft Windows login for the applicable user. |
| Siebel System Administration Guide |
