Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Configuring the Browser for Siebel Web Clients > High-Interactivity Deployment—General RequirementsThis section describes in detail the general requirements for deploying Siebel applications in high-interactivity mode. For more information, see About Deployment Modes for Siebel Web Clients. You can use the Microsoft Internet Explorer Administrator Kit and other system management tools to support high-interactivity mode deployment requirements in supported versions of Internet Explorer. Siebel Systems also provides a browser health check tool, described in Using the Browser Health Check. Customers should review the features of applicable deployment tools. Predefined Security Settings for Web Content ZonesWeb content zones in Microsoft Internet Explorer support predefined security setting templates, or groups of settings: Low, Medium-low, Medium, and High. Siebel applications support both Low and Medium-low settings; Low is preferred. You can use a zone such as Local intranet or Trusted sites for your Siebel applications and use the default security setting templates.
Using security setting templates is preferred. If you do not use them, then you may need to adjust individual security settings for the applicable Web content zone. Some procedures in this chapter describe specifying (or verifying) custom settings, for customers who cannot use security setting templates. For more information, see Manual Security Settings for High Interactivity. For more information about specifying Microsoft Internet Explorer security settings or other settings, refer to Microsoft documentation. Adjusting Printing SettingsTo enable printing Siebel application screens using the browser's Print command, Internet Explorer users must modify their printing settings.
NOTE: For information about browser requirements for supporting the Siebel application's Print command when printing through Microsoft Excel, see Manual Security Settings for High Interactivity. |
Siebel System Administration Guide |
