Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Configuring Siebel Servers > Process for Creating a Custom Siebel Server Component > Creating a Custom Siebel Server Component GroupIf you want to create your own defined components and assign them to component groups other than the predefined ones, then you first need to create component groups before creating the defined components. Component groups allow you to run related tasks and administer related components in logical groupings. This topic is an optional task in the Process for Creating a Custom Siebel Server Component. To create a custom component group
Siebel System Administration Guide |
