Siebel System Administration Guide > Siebel Enterprise Server Architecture > About Siebel Server > About Siebel Server ManagerThe Siebel Server Manager is the native management and administration interface for the Siebel Server and Siebel Enterprise Server. The Siebel Server Manager allows you to configure the parameters governing the operation of each component, and determine which Siebel Servers a given component can operate. Use the Siebel Server Manager to:
You can operate the Server Manager using one of two interfaces:
The Server Manager (both the GUI and the command-line interface) connects to the Siebel Gateway Name Server, which contains availability and connectivity information for the Siebel Servers within the Siebel Enterprise Server. The Server Manager then connects with each of the Siebel Servers and starts a Server Manager component task. If you access the GUI, Server Manager creates a task on every running Siebel Server; if you access the command-line interface without specifying a specific Siebel Server, Server Manager creates a task on every running Siebel Server; and if you start the command-line interface while specifying a specific Siebel Server (using the /s flag), Server Manager creates a task on that specific Siebel Server alone, and all commands are targeted to that Siebel Server at the server level. The Server Manager task on each Siebel Server:
NOTE: Each session of Server Manager creates a separate Server Manager task. Therefore, you create a new Server Manager task each time you access the Server Administration screens. |
| Siebel System Administration Guide |
