Siebel System Administration Guide > Configuring the System Architecture > Configuring Siebel Server Load Balancing > Verifying Load Balancing Port Access for Siebel ServersThis task is part of Troubleshooting Siebel Load Balancing. To verify load balancing port access 1 On the Web servers where SWSE is running, telnet to the SCBroker port (2321) on each Siebel Server.
For example, if a Siebel Server has the host name SiebSrvr1, then use the following command: If the connection succeeds, there is load balancing port access. The connection will time out after 500 ms.
| Siebel System Administration Guide |
