Siebel System Administration Guide > Configuring the System Architecture > Configuring Siebel Server Load Balancing > Changing the Enterprise Configuration Under Siebel Load BalancingThe most common configuration changes that affect load balancing performance are as follows: These changes require that you edit the load balancing configuration file ( Adding or Removing Siebel ServersIf you add or remove Siebel Servers that are being load-balanced, you must revise the load balancing configuration file ( Do this for all Web servers on which the Siebel Web Server Extension (SWSE) is installed. You do not need to revise the SWSE configuration file ( Use one of the following methods to revise the file:
Enabling or Disabling Application Object Managers (AOMs)If you enable or disable a load-balanced Application Object Manager, you must edit the load balancing configuration file (
After you save the file, restart the Web server. Do this for all Web servers on which the Siebel Web Server Extension (SWSE) is installed. You do not need to edit the SWSE configuration file ( |
| Siebel System Administration Guide |
