Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands >
Component Group Definition Commands
Use these commands to create, delete, assign, remove, enable, or disable component groups, and to toggle between online and offline mode. To create a component group
To assign a component group to a Siebel Server
To unassign a component group from a Siebel Server
- Enter:
unassign component group component_group_alias_name from server siebel_server_name
NOTE: Unassigning a component group from a Siebel Server results in a loss of component group customization, for example, parameter settings. Before unassigning a component group, review background information in About Assigned and Unassigned Component Groups.
To enable a component group for the Siebel Enterprise Server
- Enter:
enable component group component_group_alias_name
- Stop and restart the system service to make the changes take effect.
For more information on how to stop or start the Siebel Server System Service, see Administering the Siebel Server System Service.
This procedure works only if you did not run Siebel Server Manager command-line interface using the /s (or -s for UNIX) flag. NOTE: Before enabling a component group for the Siebel Enterprise Server, at least one component in the group must be active.
To enable a component group on a Siebel Server
- Enter:
enable component group component_group_alias_name to server siebel_server_name
NOTE: Use this command when enabling a component that was previously disabled on a particular server. Newly created component groups are enabled by default.
To change the run state of the component group to Online mode
To change the run state of the component group to Offline mode
To disable a component group for the Siebel Enterprise Server
- Enter:
disable component group component_group_alias_name
To disable a component group for a Siebel Server
- Enter:
disable component group component_group_alias_name for server siebel_server_name
To list component groups from the Siebel Gateway Name Server
- Enter:
describe component group
The describe command lists the component groups from the Siebel Gateway Name Server.
To remove a component group from a Siebel Server
To delete a component group
- Enter:
delete component group component_group_alias_name
In order for you to delete a component group, the component group cannot contain any server components or component definitions.
