Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands > Parameter Management CommandsUse parameter management commands to change the values of a parameter. To change a Siebel Enterprise Server parameter To change a component definition parameter
To change a Siebel Server parameter
To change a component parameter
After a server, component, or named subsystem parameter is modified, it ignores future parameter changes at higher levels; that is, future parameter changes at higher levels in the hierarchy do not cascade down to lower levels. Use the following commands to reinstate this functionality. To delete an enterprise parameter override To delete a Siebel Server parameter override To delete a named subsystem parameter override
Siebel System Administration Guide |
