Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands > Server Manager Command-Line PreferencesYou can create aliases for commands and configure list commands to return specific columns. These can be saved in a preferences file which is available to load the next time you open a Siebel Server manager session. The preferences file is stored in the same directory as the Server Manager program. Starting the Siebel Server Manager Command-Line Interface for the location of the Server Manager program. To create an alias for a command To delete an alias for a command To list the columns returned for a list command |
Siebel System Administration Guide |
