Testing Siebel Business Applications > Automating Load Tests > Setting Up Your Load Testing EnvironmentTo set up your environment for automated load testing using Siebel Test Automation, you must perform the following steps:
In addition, there are steps that you must perform to set up your test tool so that it will communicate properly with the Correlation Library. For more information, refer to the documentation from your test tool vendor. |
| Testing Siebel Business Applications |
