Upgrade Guide for DB2 UDB for z/OS > Reviewing the Database Upgrade Log Files >
About the Database Upgrade Logs
Upgrades: All upgrades. Environments: All environments. The Siebel Upgrade Wizard writes logs that provide detailed information on the upgrade processes and any errors that occurred when the processes were running. The Upgrade Wizard writes the logs for a process to the following directory by default: Windows: SIEBEL_ROOT\log\PROCESS
UNIX: $SIEBEL_ROOT/log/PROCESS
where PROCESS is the name of the upgrade process you have run, for example, upgrep_dev_704 or prepare_for_production_upgrade. NOTE: You can select a different log directory from the Log Output Directory screen on the Database Server Configuration utility.
The PROCESS directory contains the following subdirectories:
- Output. Directory containing the Upgrade Wizard log files.
- State. Directory containing the state.log file.
About the State Log File
Each upgrade process consists of a series of steps, each of which must complete successfully. If the Upgrade Wizard cannot complete a step, it marks the step as incomplete in the state.log file and exits. The state.log file is located in the SIEBEL_ROOT\LOG\process\state (Windows) or $SIEBEL_ROOT/LOG/process/state (UNIX) directory. You must correct the error and then run the Upgrade Wizard again. When you rerun the Upgrade Wizard, it refers to the state log and resumes at the incomplete step that contained the error. About Process Log Files
You can identify errors you encounter during an upgrade by reviewing the log file named UpgWiz.log (Windows) or srvrupgwiz1.log (UNIX) in the SIEBEL_ROOT\LOG\process\output directory (Windows) or the $SIEBEL_ROOT/LOG/process/output directory (UNIX). The name of the log file increments for subsequent log files that are created if the Siebel Upgrade Wizard encounters a problem and you have to run it again. Review the end of the log file for details about the latest failure. If the step that failed was not a native SQL step (which would be listed in the log file), then it occurred as part of an external utility for which you need to review a corresponding log file, identified by the /L parameter. How to Determine if the Upgrade Process Completed Successfully
If the status of all the steps in the state.log is Complete, the upgrade process completed successfully. If the status of any step is Incomplete, the upgrade process did not complete successfully. You must identify the error and correct it before resuming the upgrade. NOTE: In some cases, the Upgrade Wizard can complete a step even though the step contains unacceptable errors. You must verify that all steps do not contain unacceptable errors, even those with a status of Complete.
Use the following process to identify errors:
- Resolve errors for steps identified with a Status of Incomplete in the state.log file.
- Review all the steps with a status of Complete in the state.log file. If any contain unacceptable errors, resolve these errors. See Reviewing Upgrade Log Files for Errors for information on identifying unacceptable upgrade errors.
- Restart the Upgrade Wizard, or, if necessary, restore the database and rerun the upgrade process.
If you have any questions about how to resolve errors, contact Siebel Technical Support. Log Files That Can Be Ignored
If the upgrade completed successfully, there are several log files that you can safely ignore:
- Windows: sw_cfg_xxx.log and siebel.log
- UNIX: srvrupgwiz_*.log and siebel_*.log. For example, srvrupgwiz_001.log, and srvrupqwiz1_02.log
- Any other log file that existed before the start of the upgrade
CAUTION: UNIX Only: The log file srvrupgwiz_001.log is a different file to the srvrupgwiz1.log file. Do not ignore log files named srvrupgwiz1.log, srvrupgwiz1_01.log, and so on.
