Upgrade Guide for DB2 UDB for z/OS > How to Perform the Upgrade > Roadmap for Performing the Upgrade >
Roadmap for Upgrading Without a Development Environment
If you are upgrading and do not have a development environment, complete the processes in this roadmap in the order shown. Upgrading without a development environment means the following are true:
- You are running an uncustomized, out-of-the-box version of Siebel applications.
- You have not used Siebel Tools to create or modify any objects or logical schema definitions in the Siebel Repository.
- You have not modified the physical schema in the Siebel Database.
If your upgrade meets these criteria, complete the following processes in the order shown:
- Process of Planning the Upgrade.
- Preparing for a Non-Development-Environment Upgrade.
- Perform a production test upgrade. See Process of Upgrading a Production Test Environment.
- Upgrade your production environment. See Process of Upgrading a Production Environment.
