Resume the upgrade using the appropriate method for your operating system.
Windows:
- If the dialog box is still open from Pause #1 (Step 4), click Yes.
- If you closed the Siebel Upgrade Wizard screen or it is no longer open, restart the upgrade by typing the following command at the DOS command prompt from the
SIEBEL_ROOT\BIN directory:
siebupg.exe /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
For example, to restart a development environment upgrade from Release 7.0.4, enter the following command:
siebupg.exe /m master_upgrep_dev_704_mf.ucf
To restart a production environment upgrade from Release 7.0.4, enter the following command:
siebupg.exe /m master_upgrep_prod_704_mf.ucf
UNIX:
- Navigate to $
SIEBEL_ROOT/bin and enter the following command:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
srvrupgwiz /m master_upgrep_dev_704_mf.ucf
srvrupgwiz /m master_upgrep_prod_704_mf.ucf
In the Siebel Upgrade Wizard screen, click OK to resume the upgrade.
A check mark appears beside each item as it is completed.
CAUTION: The upgrade process executes in a DOS command window. Do not click inside this window while the upgrade is running. If you accidentally click inside the DOS command window, the process pauses and the word Select precedes the title of the command window. To continue, press the space bar or Escape.
The Siebel Upgrade Wizard stops again and the following message appears:
Pause #2
Please make sure your database administrator performs operations based on the files in the DDL Output Directory to complete this step. Once the operations are completed, please select Yes. To stop now and continue upgrade later, please select No. (To resume, please start the Upgrade Wizard from the command line using option /m master_upgrep_<env>_<path>_mf.ucf.)
