Upgrade Guide for DB2 UDB for z/OS > Postmerge Development Tasks >
Assigning a Category and Type to Chart Views After the Merge
Upgrades: Release 7.x not using ICL. Environments: Development environment only. Reputility log section: "Issue 4: Chart Views Needing Migration to Aggregate Type." This topic is part of an upgrade process. See How to Perform the Upgrade. The Chart menu item is relocated as of Release 7.7 and displays in the applet header. To ensure that the Chart menu item is located correctly, all the relevant charts for a view must be assigned to the same Aggregate Category. Also, each chart view must be of type Aggregate View. If the chart view is not of type Aggregate View, the chart menu item displays in a nonstandard position in the applet header. The postmerge utilities review the repository and verify that Chart views have been defined correctly. The reputility log lists the screen views that require revision. Review the section of the log referenced above and make the needed revisions. The log is located here: SIEBEL_TOOLS_INSTALL_DIR\reppatch\log\reputility.log
To assign a category and type to chart views
- Set Siebel Tools Object Explorer to Types.
- Query for the screen.
- In the Object Explorer, select Screen View.
- Query for the screen views listed in the log.
- Verify that all the views are assigned to the same category (Category Name).
The Category Name can be null.
- Verify that all the views are of type Aggregate View.
