Upgrade Guide for DB2 UDB for z/OS > Postmerge Development Tasks >
Eliminating Obsolete UI Fields After the Merge
Upgrades: Release 7.x using ICL. Environments: Development environment only. Reputility log section: "Issue 7: Fields deprecated from Business Components." This topic is part of an upgrade process. See How to Perform the Upgrade. Some of the business component fields in your installed release may be obsolete in the new release. If you have customized existing applets or created new ones, and you selected ICL during the merge, the UI may contain obsolete fields or controls. If a business component field is not available for an applet field or control after the merge, the field or control does not display. The reputility log lists the applets that contain obsolete business component fields. Review the section of the log referenced above and revise applet definitions and layouts as required. The log is located here: SIEBEL_TOOLS_INSTALL_DIR\reppatch\log\reputility.log
