Upgrade Guide for DB2 UDB for z/OS > Postupgrade Tasks for Applications >
Verifying Class and Session Times in Siebel Training
Upgrades: Releases 7.0.x, 7.5.x, 7.7.x. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform the Upgrade. At Release 7.8, the way class and session start times and end times are displayed is changed. For existing classes and sessions you must do the following:
- For classes, verify that the times displayed in the Start Date and End Date fields are correct.
- For sessions, verify that the times displayed in the Start and End fields are correct.
To verify class times are correct
- Navigate to Administration-Training > Class Details.
- In the Classes applet, expose the following hidden fields:
- For each class record, compare the time in the Start Time field with the time in the Start Date field.
- Right-click in the Start Date field to adjust the time to be the same as that in the Start Time field as required.
- Compare the time in the End Time field with the time in the End Date field.
- Right-click in the End Date field to adjust the time to be the same as that in the End Time field as required.
- Repeat this procedure for all the displayed classes.
- Hide the Start Time and End Time fields.
To verify session times
- In the sessions applet, expose the following hidden fields:
- Select a class in the Classes applet.
- For each session in the Sessions applet, compare the time in the Start Time field with the time in the Start field.
- Right-click in the Start field to adjust the time to be the same as that in the Start Time field as required.
- Compare the time in the End Time field with the time in the End field.
- Right-click in the End field to adjust the time to be the same as that in the End Time field as required.
- Select the next class in the Classes applet and repeat this procedure.
- When you have examined all the sessions for all the classes, hide the Start Time and End Time fields.
