Upgrade Guide for DB2 UDB for z/OS > Postupgrade Tasks for Applications >
Upgrading Seeded Workflows
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. Customizations to seeded workflows were saved and migrated during upgrade, but you must manually reimplement them in order for them to work properly. In Release 7.7, workflow definitions were relocated to the Tools Repository. To upgrade a seeded workflow
- In the Siebel Repository, revise each seeded workflow so that a new copy is created with a new version number.
- Manually merge in your customizations, and then deploy and activate the workflow.
