Upgrade Guide for DB2 UDB for z/OS > Basic Database Preparations >
Preserving Dock Objects and Visibility Rules
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. Changes to visibility rules and dock objects require the assistance of Technical Support or Siebel Expert Services. Modified visibility rules are dropped during a development environment upgrade. Manually record any changes to dock object visibility rules, so you can evaluate whether you must reapply the changes after the upgrade is complete. Dock objects and visibility rules created by using Docking Wizard are preserved unless they become invalid after the upgrade. Manually record any changes that you made through the Docking Wizard so that you can evaluate whether you need to reapply the changes after the upgrade is complete.
