Siebel VB Language Reference > VB Language Overview > VB Data Types > RecordsA record, or record variable, is a data structure containing one or more elements, each of which has a value. Before declaring a record variable, a Type must be defined. When the Type is defined, the variable can be declared to be of that type. The variable name should not have a type character suffix. Record elements are referenced using dot notation, for example, where record is the previously defined record name and element is a member of that record. Records can contain elements that are themselves records. |
Siebel VB Language Reference |
