Siebel eSales Administration Guide > Integrating Siebel eSales with Third-Party Shipment Tracking Applications > Process of Setting Up Shipment Tracking > Setting the Shipment Tracking-Package Tracking User PropertiesThe virtual business component from which the shipment tracking application can be launched is associated with the Request Action method and its associated Request Option. These methods invoke the External Shipment Tracking ASI when clicking the Track Shipment button on the Shipment View (eSales) view. The Request Action is Track, and it should match the shipper's system command. The Request Option is Last Package or Last Activity, which should also match the shipper's system. This task is a step in Process of Setting Up Shipment Tracking. To set the Shipment Tracking - Package Tracking business component user properties
NOTE: If you want to support integration with more than one carrier, the user property values required by the carriers will probably be different. In this case, you must employ a middleware adapter that will change the values passed to each carrier. |
| Siebel eSales Administration Guide |
