Siebel eSales Administration Guide > Integrating Siebel eSales with Third-Party Shipment Tracking Applications > Process of Setting Up Shipment Tracking >
Turning Off Package Sorting
You may want to turn off package sorting to improve performance if:
  • The order in which information is returned does not matter to you.
  • You usually only have one package in a shipment.
  • Sorting is performed in middleware.
  • Sorting is performed by the carrier's shipment tracking application.
This task is a step in Process of Setting Up Shipment Tracking.
To turn off package sorting
  1. In Siebel Tools, select the Shipment Tracking-Package Tracking business component.
  2. Select Business Component User Prop.
  3. Select the Sort Results user property.
  4. Change the value from Y to N.
