Siebel eSales Administration Guide > Integrating Siebel eSales with Third-Party Payment Applications > CyberSource Integration with Siebel eSales >
Address Verification with CyberSource
Address Verification will fail when CyberSource returns DAVSNO as the reply code. When DAVSNO is returned, an authorization code will still be returned to your Siebel application. You can use the values for the decline_avs_flags business service user property to indicate which address verification results should result in DAVSNO being returned by CyberSource. From Siebel eSales, N is passed to CyberSource, indicating that when this result is received by CyberSource for the address verification check, DAVSNO will be returned to your Siebel application. To indicate that other address verification responses should result in DAVSNO being returned to your Siebel application, add the values to the decline_avs_flags business service user property. If you want to authorize and settle at the same time, you can indicate that address verification results should be ignored by setting the ignore_avs business service user property to yes.
