Go to primary content
Oracle® Retail Bulk Data Integration Installation Guide
Release 19.0
F23581-01
  Go To Table Of Contents
Contents
Previous
Previous
B Appendix: Enabling BDI Schedules
This section provides guideline to update the status of BDI Schedules.
Schedule Status Update Instructions
All the BDI schedules are in DISABLED state by default after installation. So the user should make the required schedules ACTIVE as per the requirement. To enable the schedule the user can either User interface or the ReST end point.
To enable the schedule using the User Interface:
  1. Login to the BDI scheduler web application.
  2. Navigate to the Manage Schedules tab.
    Manage Schedules
  3. Select the Schedule in the List of Schedules table.
  4. Go to the Schedule Detail Tab below the table.
  5. Click on the Enable Schedule Icon on the top right of the Schedule Detail Panel.
    Enable Schedule
To enable/disable multiple schedules using ReST end point:
The ReST end point allows user to update status of one or more schedules in a single request.
The ReST end point returns response at schedule level.
Valid input value for scheduleStatus is: ACTIVE and DISABLED
ReST End Point Name: activateOrDisable-schedules
Method Name:
activateOrDisableSchedules
Type:
POST
Sample Request:
"scheduleStatusVo": [{
   "scheduleName": "CodeDetail_Fnd_From_RMS_Schedule",
   "scheduleStatus": "ACTIVE"
   "scheduleName": "CodeHead_Fnd_From_RMS_Schedule",
Sample Response:
{"scheduleStatusVo": [
      "message": "Schedule status updated successfully",
