Oracle® Retail Omnichannel Cloud Data Service Installation Guide Release 19.0.0 F25867-01 |
![]() Previous |
![]() Next |
Oracle Omnichannel Cloud Data Service (OCDS) has several dependencies. This section covers these requirements.
If you are unable to find the necessary version of the required Oracle infrastructure software (database server, application server, WebLogic, and so on) on the Oracle Software Delivery Cloud, you should file a non-technical Contact Us Service Request (SR) and request access to the media. For instructions on filing a non-technical SR, see My Oracle Support Note 1071023.1 - Requesting Physical Shipment or Download URL for Software Media.
The table below lists the server requirements
Supported On | Versions Supported |
Database Server OS | OS certified with Oracle Database 12c (12.1.0.2) Enterprise Edition. Options are:
Database Server 12c | Oracle Database Enterprise Edition 12c (12.1.0.2) with the following specifications:
Components:
Oneoff Patches:
Other Components:
Application Server OS | OS certified with Oracle Fusion Middleware 12c. Options are:
Application Server | Oracle Fusion Middleware 12c (12.2.1.3.0)
Components:
Patches:
Minimum required JAVA version for all operating systems | JDK 1.8+ latest security updates 64 bit |
It is recommended that the installation of OCDS is performed in the order presented in this guide.
Create OCDS Schemas.
Create a WebLogic Domain.
The following OCDS components can be installed and deployed in any order:
Install and deploy OCDS (BDI) Job Admin.
Install and deploy OCDS (RIB) Injector.
Install and deploy OCDS (ORDS) Web Services.
The installation and operation of Oracle Omnichannel Cloud Data Service (OCDS) depends several Oracle and third-party software, in addition to the OCDS distribution files. The following should be performed before starting the OCDS install process.
Install Java JDK 8 or later.
Install Oracle Database 12c (Release 12.1.0.2).
Download Oracle Fusion Middleware (WebLogic 12.2.1.3.0).
Download Oracle REST Data Services 19.2 (ords-19.2.0.199.1647zip
https://www.oracle.com/database/technologies/appdev/rest-data-services-v192-downloads.html
If upgrading from a previous Oracle REST Data Service follow the instructions provided in the download package.
