| Oracle® Retail Integration Bus Hospital Administration Guide Release 19.0 F22946-02 |
![]() Previous |
![]() Next |
Oracle Retail Integration Bus Hospital Administration or RIB Hospital Administration (RIHA) is a tool to manage RIB messages in the RIB hospital error tables.
Using RIHA you can search for hospital records, stop a message from being retried, retry a message for which maximum system-set retries have been tried, and delete a message from the tables. You can insert new records into hospital tables. You can also update existing hospital records and message payloads.
RIHA should be installed only after core RIB components have been installed and verified.
Using RIHA is the recommended way to perform all RIB Hospital error table operations.
