Go to primary content
Oracle® Retail Functional Artifact Generator Guide
Release 19.0
F22944-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
B Appendix: Example of Customization and Localization for ASNInDesc
This appendix provides a sample customization and localization of ASNInDesc, which is used as input to create custom and localization templates in various examples in this document.
Surrounding text describes 13.2.4-14.PNG.
Note that the XSD contains no extension hooks (such as import statements and reference elements). After the custom template is created, the extension hook for customization is added to ASNInDesc.xsd.
Surrounding text describes 13.2.4-15.PNG.
The reference element is added to ASNInDesc complex type, as shown in the following screen.
Surrounding text describes 13.2.4-16.PNG.
Similarly, for localization (such as Brazil), the import statement and reference elements are added to ASNInDesc.xsd, as shown in the following screen.
Surrounding text describes 13.2.4-17.PNG.
Surrounding text describes 13.2.4-18.PNG.
The custom template, ExtOfASNInDesc.xsd, is created from the tool, as shown in the following screen.
Surrounding text describes 13.2.4-19.PNG.
The localization template created from the tool appears as follows in the illustrations of LOCOfASNInDesc.xsd, BrASNInDesc.xsd, and EOfBrASNInDesc.xsd.
LocOfASNInDesc.xsd
Surrounding text describes 13.2.4-20.PNG.
BrASNInDesc.xsd
Surrounding text describes 13.2.4-21.PNG.
EOfBrASNInDesc.xsd
Surrounding text describes 13.2.4-22.PNG.
