| Oracle® Retail Integration Bus Service-Oriented Architecture Enabler Tool Guide Release 19.0 F22952-01 |
![]() Previous |
![]() Next |
The sample below can be used as an initial template.
<serviceProviderDefLibrary appName="rms"
xmlns="http://www.oracle.com/retail/integration/services/serviceProviderDefLibrary/v1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<service name="Supplier"><!-- Noun, don't put suffix Service -->
<documentation />
<operation name="create"><!-- Verb -->
<documentation>Create a new SupplierDesc.</documentation>
<input type="SupplierDesc"><!-- Existing BO -->
<documentation>
Input SupplierDesc to create.
</documentation>
</input>
<output type="SupplierRef">
<documentation>
Return the SupplierRef for the newly created
SupplierDesc.
</documentation>
</output>
<fault faultType="IllegalArgumentWSFaultException">
<documentation>
Throw this exception when it is "soap:Client" side
message problem.
</documentation>
</fault>
<fault
faultType="EntityAlreadyExistsWSFaultException">
<documentation>
Throw this exception when the object already exist.
</documentation>
</fault>
<fault faultType="IllegalStateWSFaultException">
<documentation>
Throw this exception when there is unknown
"soap:Server" side problem.
</documentation>
</fault>
</operation>
<operation name="createSupSiteUsing"><!-- Verb -->
<documentation>Create a new SupplierSite.</documentation>
<documentation>
</documentation>
</input>
<documentation>
SupplierDesc.
</documentation>
</output>
<documentation>
message problem.
</documentation>
</fault>
<fault
<documentation>
</documentation>
</fault>
<documentation>
</documentation>
</fault>
</operation>
<operation name="createSupSiteAddrUsing"><!-- Verb -->
<documentation>
</documentation>
</input>
<documentation>
SupplierDesc.
</documentation>
</output>
<documentation>
message problem.
</documentation>
</fault>
<fault
<documentation>
</documentation>
</fault>
<documentation>
</documentation>
</fault>
</operation>
<operation name="update">
<input type="SupplierDesc" />
<output type="SupplierDesc" />
<fault faultType="IllegalArgumentWSFaultException" />
<fault
faultType="EntityNotFoundWSFaultException" />
<fault faultType="IllegalStateWSFaultException" />
</operation>
<operation name="updateSupSiteUsing">
<fault
</operation>
<operation name="updateSupSiteOrgUnitUsing">
<fault
</operation>
<operation name="updateSupSiteAddrUsing">
<fault
</operation>
<operation name="find" suffix="outputType">
<input type="SupplierRef" />
<fault
</operation>
<operation name="delete">
<output type="SupplierRef" />
<fault
</operation>
<input type="SupplierCollectionDesc" />
<output type="SupplierCollectionRef" />
<fault faultType="EntityAlreadyExistsWSFaultException" />
</operation>
<output type="SupplierCollectionDesc" />
<fault
</operation>
<input type="SupplierCollectionRef" />
<fault
</operation>
<fault
</operation>
</service>
</serviceProviderDefLibrary>
Following is a sample service definition xml for REST services:
<serviceProviderDefLibrary appName="rms" xmlns="http://www.oracle.com/retail/integration/services/serviceProviderDefLibrary/v1"
<service name="Suppliers">
<operation name="find" operationType="READ_WITH_IDENTITY" suffix="outputType">
<input type="Nothing" identifierNameList="sup_xref_key,supplier_id"/>
<output type="SupplierDesc">
</output>
</operation>
<operation name="create" operationType="CREATE">
<input type="SupplierDesc" identifierNameList="sup_xref_key,supplier_id"/>
</output>
</operation>
<operation name="update" operationType="UPDATE">
<output type="Nothing">
</output>
</operation>
<operation name="delete" operationType="DELETE">
</output>
</operation>
<operation name="searchAll" operationType="READ_WITH_PREDICATE" suffix="outputType">
<input type="Nothing" queryParamList="country_id"/>
<output type="SupplierColDesc">
</output>
</operation>
<operation name="createAll" operationType="CREATE">
<input type="SupplierColDesc"/>
<output type="SupplierColRef">
</output>
</operation>
<operation name="updateAll" operationType="UPDATE">
</output>
</operation>
<operation name="deleteAll" operationType="DELETE">
<input type="SupplierColDesc" queryParamList="country_id"/>
</output>
</operation>
</service>
<service name="PayTerm">
<input type="PayTermRef" identifierNameList="terms_xref_key,terms"/>
<output type="PayTermDesc">
</output>
</operation>
<operation name="calculateTotal" operationType="PROCESS">
<input type="PayTermDesc" />
<output type="PayTermRef">
</output>
</operation>
</service>
<service name="CustOrdItm">
<input type="ReferenceId" identifierNameList="id"/>
<output type="CustOrdItmPkVo">
</output>
</operation>
<input type="CustOrdItmPkVo"/>
<output type="ReferenceId">
</output>
</operation>
<operation name="taxLines" operationType="NAVIGATE_TO_CHILD">
<input type="Nothing" queryParamList="tax_id"/>
<output type="TaxLinePkColVo">
</output>
</operation>
</service>
<service name="Customers">
<operation name="searchAll" operationType="READ_WITH_PREDICATE" suf-fix="outputType">
<input type="Nothing" queryParamList="customer_type"/>
<output type="CustomerColDesc">
</output>
</operation>
</service>
