| Oracle® Retail Integration Bus Cloud Service Installation Guide Release 19.0.000 F25610-01 |
![]() Previous |
![]() Next |
This appendix includes a code sample for configWss.py.
userName = sys.argv[1]
passWord = sys.argv[2]
url="t3://"+sys.argv[3]+":"+sys.argv[4]
print "Connect to the running adminSever"
connect(userName, passWord, url)
edit()
startEdit()
#Enable assert x509 in SecurityConfiguration
rlm = cmo.getSecurityConfiguration().getDefaultRealm()
ia = rlm.lookupAuthenticationProvider("DefaultIdentityAsserter")
activeTypesValue = list(ia.getActiveTypes())
existed = "X.509" in activeTypesValue
if existed == 1:
print 'assert x509 is aleady enabled'
else:
activeTypesValue.append("X.509")
ia.setActiveTypes(array(activeTypesValue,java.lang.String))
ia.setDefaultUserNameMapperAttributeType('CN');
ia.setUseDefaultUserNameMapper(Boolean('true'));
#Create default WebServcieSecurity
securityName='default_wss'
defaultWss=cmo.lookupWebserviceSecurity(securityName)
if defaultWss == None:
print 'creating new webservice security bean for: ' + securityName
defaultWss = cmo.createWebserviceSecurity(securityName)
else:
print 'found exsiting bean for: ' + securityName
#Create credential provider for DK
cpName='default_dk_cp'
wtm=defaultWss.lookupWebserviceCredentialProvider(cpName)
if wtm == None:
wtm = defaultWss.createWebserviceCredentialProvider(cpName)
wtm.setClassName('weblogic.wsee.security.wssc.v200502.dk.DKCredentialProvider')
wtm.setTokenType('dk')
cpm = wtm.createConfigurationProperty('Label')
cpm.setValue('WS-SecureConversationWS-SecureConversation')
cpm = wtm.createConfigurationProperty('Length')
cpm.setValue('16')
else:
print 'found exsiting bean for: DK ' + cpName
#Create credential provider for x.509
cpName='default_x509_cp'
if wtm == None:
wtm.setClassName('weblogic.wsee.security.bst.ServerBSTCredentialProvider')
wtm.setTokenType('x509')
else:
print 'found exsiting bean for: x.509 ' + cpName
#Custom keystore for xml encryption
cpName='ConfidentialityKeyStore'
cpm=wtm.lookupConfigurationProperty(cpName)
if cpm == None:
cpm = wtm.createConfigurationProperty(cpName)
keyStoreName=sys.argv[5]
cpm.setValue(keyStoreName)
cpName='ConfidentialityKeyStorePassword'
if cpm == None:
cpm.setEncryptValueRequired(Boolean('true'))
KeyStorePasswd=sys.argv[6]
cpm.setEncryptedValue(KeyStorePasswd)
cpName='ConfidentialityKeyAlias'
if cpm == None:
keyAlias=sys.argv[7]
cpm.setValue(keyAlias)
cpName='ConfidentialityKeyPassword'
if cpm == None:
cpm = wtm.createConfigurationProperty('ConfidentialityKeyPassword')
keyPass=sys.argv[8]
cpm.setEncryptedValue(keyPass)
#Custom keystore for xml digital signature
cpName='IntegrityKeyStore'
if cpm == None:
cpName='IntegrityKeyStorePassword'
if cpm == None:
cpm.setEncryptValueRequired(Boolean('true'))KeyStorePasswd=sys.argv[6]cpm.setEncryptedValue(KeyStorePasswd)cpName='IntegrityKeyAlias'cpm=wtm.lookupConfigurationProperty(cpName)if cpm == None: cpm = wtm.createConfigurationProperty(cpName)keyAlias=sys.argv[7]cpm.setValue(keyAlias)cpName='IntegrityKeyPassword'cpm=wtm.lookupConfigurationProperty(cpName)if cpm == None: cpm = wtm.createConfigurationProperty(cpName)cpm.setEncryptValueRequired(Boolean('true'))keyPass=sys.argv[8]cpm.setEncryptedValue(keyPass)#Create token handler for x509 token#cpName='default_x509_handler'th=defaultWss.lookupWebserviceTokenHandler(cpName)if th == None: th = defaultWss.createWebserviceTokenHandler(cpName) th.setClassName('weblogic.xml.crypto.wss.BinarySecurityTokenHandler') th.setTokenType('x509') cpm = th.createConfigurationProperty('UseX509ForIdentity') cpm.setValue('true')save()activate(block="true")disconnect()exit()
