| Oracle® Retail Cloud Service Functional Artifacts Guide Release 19.0.000 F25446-01 |
![]() Previous |
![]() Next |
The following is a list of reference materials providing more information on the topics covered in this guide.
[XML] Extensible Markup Language (XML) 1.0 (Second Edition) http://www.w3.org/TR/REC-xml
[XMLSchema1] W3C Recommendation, XML Schema Part 1: Structures http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/
[XMLSchema2] W3C Recommendation, XML Schema Part 2: Datatypes
[OAGINDR] OAGi OAGIS 9.0 Naming and Design Rules Standard version 0.7, published September 30, 2005
[CCTS] UN/CEFACT Core Components Technical Specification Draft 2.2, published March 31 ,2006.
[UNCEFACTNDR] UN/CEFACT XML Naming and Design Rules, Draft 2.0, published January 20, 2006
Oracle Application Integration Architecture - Enterprise Object Library 2.2: Enterprise Business Objects and Messages XML Naming and Design Rules Part No. E12769-01 August 2008.
ARTS SOA Best Practices Technical Report Version 1.2.0 November 19, 2008 - Candidate Recommendation.
"Web Service Contract Design and Versioning for SOA," Thomas Erl, et. al., September 2008, Prentice Hall.
WS-I Basic Profile 1.1. http://www.ws-i.org/Profiles/BasicProfile-1.1.html
