| Oracle® Retail Cloud Service Functional Artifacts Guide Release 19.0.000 F25446-01 |
![]() Previous |
![]() Next |
The Oracle Retail Artifacts Guide provides detailed information about how Oracle Retail artifacts are designed and packaged for release, as well as the standards used in their creation.
This Oracle Retail Artifacts Guide is intended for users of Oracle Retail applications, particularly application integrators, implementation staff, and retail IT personnel.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
For more information, see the following documents in the Oracle Retail Integration Bus documentation set:
Oracle Retail Integration Cloud Service Release Notes
Oracle Retail Integration Cloud Service Action List
Oracle Retail Integration Cloud Services Administration Guide
Oracle Retail Integration Bus Implementation Guide
Oracle Retail Integration Bus Installation Guide
Oracle Retail Integration Bus Operations Guide
Oracle Retail Integration Bus Hospital Administration Guide
Oracle Retail Integration Bus Support Tools Guide
Oracle Retail Functional Artifact Generator Guide
Oracle Retail Service-Oriented Architecture Enabler Tool Guide
Oracle Retail Integration Bus Java Messaging Service Console Guide
Oracle Retail Service Backbone Developers Guide
Oracle Retail Service Backbone Implementation Guide
Oracle Retail Integration Console (RIC) User Guide
Oracle Retail Service Backbone Security Guide
Oracle Retail Bulk Data Integration Implementation Guide
Oracle Retail Bulk Data Integration Installation Guide
Oracle Retail Financial Integration for Oracle Retail Merchandise Operations Management and Oracle Financials Implementation Guide
Oracle Retail Financial Integration for Oracle Retail Merchandise Operations Management and Oracle Financials Installation Guide
Oracle Retail Job Orchestration and Scheduler Implementation Guide
To contact Oracle Customer Support, access My Oracle Support at the following URL:
https://support.oracle.com
When contacting Customer Support, please provide the following:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
When you install the application for the first time, you install either a base release (for example, 19.0.0 or 19.0.000) or a later patch release (for example, 19.0.1 or 19.0.010). If you are installing the base release, additional patch, and bundled hot fix releases, read the documentation for all releases that have occurred since the base release before you begin installation. Documentation for patch and bundled hot fix releases can contain critical information related to the base release, as well as information about code changes since the base release.
To more quickly address critical corrections to Oracle Retail documentation content, Oracle Retail documentation may be republished whenever a critical correction is needed. For critical corrections, the republication of an Oracle Retail document may at times not be attached to a numbered software release; instead, the Oracle Retail document will simply be replaced on the Oracle Technology Network Web site, or, in the case of Data Models, to the applicable My Oracle Support Documentation container where they reside.
This process will prevent delays in making critical corrections available to customers. For the customer, it means that before you begin installation, you must verify that you have the most recent version of the Oracle Retail documentation set. Oracle Retail documentation is available on the Oracle Technology Network at the following URL:
http://www.oracle.com/technetwork/documentation/oracle-retail-100266.html
An updated version of the applicable Oracle Retail document is indicated by Oracle part number, as well as print date (month and year). An updated version uses the same part number, with a higher-numbered suffix. For example, part number E123456-02 is an updated version of a document with part number E123456-01.
If a more recent version of a document is available, that version supersedes all previous versions.
Oracle Retail product documentation is available on the following web site:
(Data Model documents are not available through Oracle Technology Network. You can obtain them through My Oracle Support.)
The following text conventions are used in this document:
| Convention | Meaning |
| boldface | Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
| italic | Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
monospace |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
