| Oracle® Retail Financial Integration for Oracle Retail Merchandise Operations Management and Oracle Financials Installation Guide Installation Guide Release 19.0.1 F44785-01 |
![]() Previous |
Table B-2 EBS – JSON Configuration
| RFI Configuration Property Name | Description | Example Value/Default Value | Value Editable? |
RfiDeploymentEnvInfo |
integrationToEbsOrPsftOrCfin |
EBS |
N |
DataSourceDef |
EbsDataSource |
EBS database connection details |
dataSourceName |
Name of the datasource that the installer creates to connect to EBS |
EbsDataSource |
N |
dataSourceClass |
DataSource class the installer will configure for the data source |
oracle.jdbc.xa.client.OracleXADataSource |
N |
dataSourceJndiName |
JNDI Name used by the RFI application to connect to the database |
jdbc/EbsDataSource |
N |
jdbcUrl |
EBS JDBC connection URL. Specify the connection URL for your EBS installation. |
jdbc:oracle:thin:@//ebsdbhost.example.com:1521/orcl |
Y |
jdbcUserAlias |
EBS user name alias. Do not change the default value. |
ebsDataSourceUserAlias |
N |
jdbcUser |
User (schema name) for the EBS database. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the EBS database. |
GET_FROM_WALLET |
N |
RmsDataSource |
RMS database connection details |
dataSourceName |
Name of the datasource that the installer creates to connect to RMS database |
RmsDataSource |
N |
dataSourceClass |
oracle.jdbc.OracleDriver |
N |
JNDI name used by the RFI application to connect to the AQ database |
jdbc/RmsDataSource |
N |
jdbcUrl |
RMS JDBC connection URL. Specify the connection URL for RMS DB. |
jdbc:oracle:thin:@//rmsdbhost.example.com:1521/orcl |
Y |
jdbcUserAlias |
User name alias. Do not change the default value. |
rmsDataSourceUserAlias |
N |
jdbcUser |
User (schema name) for the RMS database. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the RMS database. |
GET_FROM_WALLET |
N |
RfiDataSource |
RFI database connection details |
dataSourceName |
Name of the datasource that the installer creates to connect to RFI database. |
RfiDataSource |
N |
dataSourceClass |
N |
jdbc/RfiDataSource |
N |
jdbcUrl |
RFI JDBC connection URL. Please specify the connection URL for your RFI DB. |
jdbc:oracle:thin:@//rfidbhost.example.com:1521/orcl |
Y |
jdbcUserAlias |
rfiDataSourceUserAlias |
N |
jdbcUser |
User (schema name) for the RFI database. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the RFI database. |
GET_FROM_WALLET |
N |
OdiMasterDataSource |
ODI Master Repository database connection details |
dataSourceName |
ODI database's data source name used to identify the data source to ODBC. |
N |
dataSourceClass |
DataSource class that the installer will use to configure the data source |
N |
JNDI name used by the RFI application to connect to the database |
jdbc/OdiMasterDataSource |
N |
jdbcUrl |
ODI JDBC connection URL |
jdbc:oracle:thin:@//odimasterhostname.us.custom.com:1521/plgdb |
Y |
jdbcUserAlias |
Jdbc user name alias. Do not change the default value. |
odiMasterDataSourceUserAlias |
N |
jdbcUser |
User (schema name) for the ODI master repository database. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the ODI master repository database. |
GET_FROM_WALLET |
N |
OdiWorkDataSource |
ODI work repository database connection details |
dataSourceName |
Data source name used to identify ODI work database Do not change the default value. |
OdiWorkDataSource |
N |
dataSourceClass |
Datasource class. Do not change the default value. |
N |
JNDI name, in case JNDI is used for connection. Do not change the default value. |
jdbc/OdiWorkDataSource |
N |
jdbcUrl |
ODI JDBC connection URL. |
jdbc:oracle:thin:@//odiworkhostname.us.custom.com:1521/plgdb |
Y |
jdbcUserAlias |
JDBC user name alias for work repository schema. Do not change the default value. |
odiWorkDataSourceUserAlias |
N |
jdbcUser |
DB user name for the ODI work repository schema. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the ODI ODI work repository schema. |
GET_FROM_WALLET |
N |
OdiStagingAreaDataSource |
ODI Staging Area database connection details |
dataSourceName |
ODI staging database connection details. It is recommended to have the ODI staging schema (RFI_ODI_TEMP) in the EBS or PeopleSoft database. |
N |
dataSourceClass |
ODI staging datasource class. Do not change the default. |
N |
ODI staging JNDI name. Do not change the default value. |
jdbc/OdiStagingAreaDataSource |
N |
jdbcUrl |
ODI RFI staging area JDBC connection URL. |
jdbc:oracle:thin:@//odistaginghostname.us.custom.com:1521/plgdb |
Y |
jdbcUserAlias |
JDBC user name alias for staging repository. Do not change the defaults. |
odiStagingAreaDataSourceUserAlias |
N |
jdbcUser |
DB User name for the ODI Staging Area schema. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the ODI Staging Area schema. |
GET_FROM_WALLET |
N |
MiddlewareServerDef |
RfiAppServer |
RfiAppServer- WebLogic domain configuration details |
weblogicDomainName |
RfiAppServer configuration, WebLogic domain name |
RFIDomain |
Y |
weblogicDomainHome |
RFI domain home. |
<WLS-HOME>/user_projects/domains/RFIDomain |
Y |
weblogicDomainAdminServerUrl |
WebLogic domain admin server URL. |
t3://rfiserver.example.com:19301 |
Y |
weblogicDomainAdminServerProtocol |
WebLogic admin server protocol. |
t3 |
N |
weblogicDomainAdminServerHost |
Weblogic server host name. |
rfiserver.example.com |
Y |
weblogicDomainAdminServerPort |
Port information of weblogic server. |
19301 |
Y |
weblogicDomainAdminServerUserAlias |
Weblogic server User name alias. |
rfiAppServerAdminServerUserAlias |
N |
weblogicDomainTargetManagedServerName |
Weblogic Domain Target Managed Server name. |
rfi-server |
Y |
glAccountValidationServiceEndPointUrl |
End point URL for GL account validation Service without RSB configuration. |
http://myhostname:7001/GlAccountValidationBean/GlAccountValidationService?WSDL |
Y |
glAccountValidationServiceEndPointUserAlias |
User alias information for GL account validation service. Do not change the default value. |
N |
glAccountValidationServiceEndPointUser |
End point User name. |
GET_FROM_WALLET |
N |
glAccountValidationServiceEndPointPassword |
End point User password. |
GET_FROM_WALLET |
N |
glAccountValidationServiceEndPointSecurityPolicyName |
Security policy for the service. Valid values are PolicyA, PolicyB and unsecure.(Note: Use https for Policy A setting) |
unsecure |
Y |
rfiAdminUiUrl |
URL for RFI Admin UI. |
http://myhostname:7001/retail-financial-integration-web |
Y |
rfiAdminUiUserGroup |
Admin user group. Do not change the default value. |
RfiAdminGroup |
N |
rfiAdminUiUserAlias |
RFI admin UI user name alias. Do not change the default value. |
N |
rfiAdminUiUser |
RFI admin UI user name. |
GET_FROM_WALLET |
N |
rfiAdminUiPassword |
End point user password. |
GET_FROM_WALLET |
N |
smtpServerHost |
RFI SMTP (Simple Mail Transfer Protocol) server host information. |
smtp.example.com |
Y |
smtpServerPort |
RFI SMTP server port information. |
465 |
Y |
smtpServerListenerType |
RFI SMTP server listener type (for example, SSL or TSL). |
SSL |
N |
smtpAuthenticationRequired |
Enter "TRUE" if authentication required for SMTP server, else "FALSE". |
TRUE |
Y |
smtpMailFromAddress |
Enter the sender email Address. |
sender_email_address@example.com |
Y |
smtpMailFromAddressAlias |
Alias for From Address. Do not change the default value. |
N |
smtpMailFromAddressPassword |
Password for the from email address. |
GET_FROM_WALLET |
N |
smtpMailToAddressList |
Comma seperated list of receipient email addresses. |
receiver_email_address@abc.com, receiver_email_address2@abc.com |
Y |
IgsAppServer |
RFI Integrated Gateway Services detail for Currency Rate service |
currencyRateServiceEndPointUrl |
IGS Currency Rate endpoint URL (if no RSB is configured). |
http://igshostname:19201/CurRatePublishingBean/CurRatePublishingService?wsdl |
Y |
IGS Currency Rate endpoint URL (If RSB is configured). |
http://igshostname:19201/igs-CurRatePublishing-AppServiceDecorator/ProxyService/CurRatePublishingAppServiceProxy?wsdl |
Y |
currencyRateServiceEndPointUserAlias |
Alias for Currency Rate service End point User Alias. Do not change default value. |
N |
currencyRateServiceEndPointUser |
UserName for Currency Rate service. |
GET_FROM_WALLET |
N |
currencyRateServiceEndPointPassword |
Password for Currency Rate service. |
GET_FROM_WALLET |
N |
currencyRateServiceEndPointSecurityPolicyName |
Security policy for the service. Valid values are PolicyA, PolicyB and unsecure. (Note: Use https for Policy A setting) |
unsecure |
Y |
currencyRateServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias |
WSKeyStore Password User Alias for Currency Rate service End point PolicyB. |
currencyRate#keystore-password-user-alias |
N |
currencyRateServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias |
WSKeyPublicPrivateKey Alias forCurrency Rate service End point User PolicyB. |
currencyRate#remote-host-public-private-key-alias |
N |
RmsAppServer |
RFI Integrated Gateway Services detail for Supplier service |
supplierServiceEndPointUrl |
Supplier service endpoint URL information (with no RSB). |
http://rmshostname.example.com:19203/SupplierBean/SupplierService?WSDL |
Y |
Supplier service endpoint URL (with RSB). |
http://rmshostname.example.com:19203/rms-Supplier-AppServiceDecorator/ProxyService/SupplierAppServiceProxy?wsdl |
Y |
supplierServiceEndPointUserAlias |
Alias for Supplier service. Do not change the default. |
N |
supplierServiceEndPointUser |
UserName for Supplier Service End point User. |
GET_FROM_WALLET |
N |
supplierServiceEndPointPassword |
Password for Supplier service. |
GET_FROM_WALLET |
N |
supplierServiceEndPointSecurityPolicyName |
unsecure |
Y |
supplierServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias |
WSKeyStore Password User Alias for Supplier Service End point User Alias. |
supplier#keystore-password-user-alias |
N |
supplierServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias |
WSKeyPublicPrivateKey Alias for Supplier Service End point User Alias. |
supplier#remote-host-public-private-key-alias |
N |
EbsAppServer |
EBS App Server Configuration Details |
ebsInstanceJavaTopLocation |
EBS server $JAVA_TOP folder path.Note: If EBS is installed on Oracle Application Server substitute the corresponding OAS/oc4j information instead of WebLogic server information |
/u01/applmgr/apps/apps_st/comn/java/classes |
Y |
EBS WebLogic Domain Name. |
ebs_domain |
Y |
EBS WebLogic Domain Home. |
/path/ebs_domain |
Y |
EBS WebLogic domain admin server URL. |
t3://ebshostname:7001 |
Y |
EBS WebLogic domain admin server user alias |
ebsAppServerAdminServerUserAlias |
N |
weblogicDomainAdminServerUser |
EBS WebLogic admin server user name. |
GET_FROM_WALLET |
N |
weblogicDomainAdminServerPassword |
EBS WebLogic admin server password. |
GET_FROM_WALLET |
N |
RfiBulkServer |
RFI Bulk Server ODI Configuration Details |
odiHost |
ODI host name. Host name of the machine where ODI is installed. |
Odihostname |
Y |
odiUrl |
Path in machine name(odihostname), where ODI is installed. |
/path_where_odi_is_installed/oracledi/agent |
Y |
odiUserAlias |
ODI user alias. Do not change the default |
rfiBulkServerOdiUserAlias |
N |
odiUser |
ODI User Name. |
GET_FROM_WALLET |
N |
odiPassword |
ODI user name password. |
GET_FROM_WALLET |
N |
odiAgentHost |
ODI agent host name. Name of the machine where ODI agent is installed. Typically, this is the same machine which is a source. |
odihostname |
Y |
odiAgentPort |
ODI agent port information. Constant/ recommended to be 20910. |
20910 |
Y |
Table B-3 PeopleSoft – JSON Configuration
PSFT |
N |
DataSourceDef |
PsftDataSource |
Peoplesoft database connection details |
dataSourceName |
Name of the datasource that the installer creates to connect to Peoplesoft |
PsftDataSource |
N |
dataSourceClass |
N |
jdbc/PsftDataSource |
N |
jdbcUrl |
Peoplesoft JDBC connection URL. Specify the connection URL for your Peoplesoft installation. |
Y |
jdbcUserAlias |
Peoplesoft user name alias. Do not change the default value. |
psftDataSourceUserAlias |
N |
jdbcUser |
User (schema name) for the Peoplesoft database. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the Peoplesoft database |
GET_FROM_WALLET |
N |
RmsDataSource |
dataSourceName |
Name of the datasource that the installer creates to connect to RMS |
RmsDataSource |
N |
dataSourceClass |
N |
N |
jdbcUrl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the RMS database |
GET_FROM_WALLET |
N |
RfiDataSource |
dataSourceName |
Name of the datasource that the installer creates to connect to RFI |
RfiDataSource |
N |
dataSourceClass |
N |
N |
jdbcUrl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
dataSourceName |
N |
dataSourceClass |
N |
N |
jdbcUrl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
OdiWorkDataSource |
dataSourceName |
OdiWorkDataSource |
N |
dataSourceClass |
N |
N |
jdbcUrl |
Y |
jdbcUserAlias |
N |
jdbcUser |
User name for the ODI work repository schema. |
GET_FROM_WALLET |
N |
jdbcPassword |
Password for the ODI work repository schema. |
GET_FROM_WALLET |
N |
dataSourceName |
N |
dataSourceClass |
N |
N |
jdbcUrl |
ODI RFI staging area JDBC connection URL |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
RfiAppServer |
RFIDomain |
Y |
RFI domain home. |
Y |
Y |
t3 |
N |
Y |
19301 |
Y |
Weblogic server UserAlias name. Do not change defaults |
N |
rfi-server |
Y |
End point URL for GL account validation Service |
Y |
N |
GET_FROM_WALLET |
N |
End point User password. This information is sourced from a container that is used for storing authentication and signing credentials and is managed by Security Admins. |
GET_FROM_WALLET |
N |
unsecure |
Y |
drillBackForwardUrlServiceEndPointUrl |
End point URL for drillBackForward Service without RSB configuration. |
http://myhostname:7001/DrillBackForwardUrlBean/DrillBackForwardUrlService?WSDL |
Y |
End point URL for drillBackForward Service with RSB configuration. |
http://myhostname:7001/fin-DrillBackForwardUrl-AppServiceDecorator/ProxyService/DrillBackForwardUrlAppServiceProxy?wsdl |
Y |
drillBackForwardUrlServiceEndPointUserAlias |
N |
drillBackForwardUrlServiceEndPointUser |
DrillBackForward Url Service End point User name. |
GET_FROM_WALLET |
N |
drillBackForwardUrlServiceEndPointPassword |
DrillBackForward Url Service End point User password. |
GET_FROM_WALLET |
N |
drillBackForwardUrlServiceEndPointSecurityPolicyName |
Indicates how the Policy is secured. Options are Policy A, Policy B or Unsecure. |
unsecure |
Y |
supplierBusinessEventHandlerServiceEndPointUrl |
URL information that will be used in connection for Supplier Business Event handler Service. |
http://myhostname:7001/SupplierBusinessEventHandlerBean/SupplierBusinessEventHandlerService?WSDL |
Y |
supplierBusinessEventHandlerServiceEndPointUserAlias |
User Alias. Constant at Supplier Business Event handler Service User Alias. |
N |
supplierBusinessEventHandlerServiceEndPointUser |
Supplier Business Event handler Service User name. |
GET_FROM_WALLET |
N |
supplierBusinessEventHandlerServiceEndPointPassword |
Supplier Business Event handler Service End point User password. |
GET_FROM_WALLET |
N |
supplierBusinessEventHandlerServiceEndPointSecurityPolicyName |
Indicates how the Policy is secured. Options are Policy A, Policy B or Unsecure. (Note: Use https for Policy A setting) |
unsecure |
Y |
payTermBusinessEventHandlerServiceEndPointUrl |
End point URL for PaytermBusiness Event Handler Service. |
http://myhostname:7001/PayTermBusinessEventHandlerBean/PayTermBusinessEventHandlerService?WSDL" |
Y |
payTermBusinessEventHandlerServiceEndPointUserAlias |
User Alias. Constant at payTermBusinessEventHandlerServiceEndPointUserAlias. |
N |
payTermBusinessEventHandlerServiceEndPointUser |
PaytermBusiness Event Handler Service End point User name. |
GET_FROM_WALLET |
N |
payTermBusinessEventHandlerServiceEndPointPassword |
PaytermBusiness Event Handler Service End point User password. |
GET_FROM_WALLET |
N |
payTermBusinessEventHandlerServiceEndPointSecurityPolicyName |
unsecure |
Y |
rfiAdminUiUrl |
Y |
RfiAdminGroup |
N |
N |
rfiAdminUiUser |
RFI Admin UI User name. |
GET_FROM_WALLET |
N |
GET_FROM_WALLET |
N |
smtpServerHost |
smtp.example.com |
Y |
smtpServerPort |
465 |
Y |
SSL |
N |
TRUE |
Y |
Y |
N |
GET_FROM_WALLET |
N |
Y |
IgsAppServer |
Y |
Y |
N |
GET_FROM_WALLET |
N |
Password for for Currency Rate service. |
GET_FROM_WALLET |
N |
unsecure |
Y |
N |
N |
RmsAppServer |
Y |
Y |
N |
GET_FROM_WALLET |
N |
GET_FROM_WALLET |
N |
unsecure |
Y |
N |
N |
PsftAppServer |
PSFT App Server Configuration Details |
PSFT WebLogic Domain Name. |
ebs_domain |
Y |
PSFT WebLogic Domain Home. |
/path/ebs_domain |
Y |
PSFT WebLogic domain admin server URL. |
Y |
PSFT WebLogic domain admin server user alias |
psftAppServerAdminServerUserAlias |
N |
PSFT WebLogic admin server user name. |
GET_FROM_WALLET |
N |
PSFT WebLogic admin server password. |
GET_FROM_WALLET |
N |
psftApplicationUrl |
Peoplesoft Application URL. |
http://psfthostname:7777/psp |
Y |
psftApplicationUrlSite |
Path of Application URL in peoplesoft domain |
ps |
N |
psftApplicationUrlPortalNodeContent |
Peoplesoft Application URL portal node content. |
EMPLOYEE/ERP/c |
N |
psftApplicationUserAlias |
Peoplesoft Application URL domain admin server useralias |
N |
psftApplicationUser |
Peoplesoft Application URL UserName. |
GET_FROM_WALLET |
N |
psftApplicationPassword |
Peoplesoft Application URL User Password. |
GET_FROM_WALLET |
N |
comboChartFieldServiceEndPointUrl |
PeopleSoft comboChart Field service End point URL. |
http://psfthostname:7777/PSIGW/PeopleSoftServiceListeningConnector/COMBO_CF_EDIT_REQUEST.1.wsdl |
Y |
comboChartFieldServiceEndPointUserAlias |
PeopleSoft comboChart Field service End point User Alias. |
N |
comboChartFieldServiceEndPointUser |
PeopleSoft comboChart Field service End point Username. |
GET_FROM_WALLET |
N |
comboChartFieldServiceEndPointPassword |
PeopleSoft comboChart field service End point Username Password. |
GET_FROM_WALLET |
N |
comboChartFieldServiceEndPointSecurityPolicyName |
unsecure |
Y |
comboChartFieldServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias |
PeopleSoft comboChart field service End point WebserviceKeyStore Password User alias. |
payTerm#keystore-password-user-alias |
N |
comboChartFieldServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias |
PeopleSoft comboChart field service End point Web service Keyprivate key alias. |
payTerm#remote-host-public-private-key-alias |
N |
rfiInvoiceDrillForwardServiceEndPointUrl |
RFI Invoice drill forward service End point URL |
http://psfthostname:7777/PSIGW/PeopleSoftServiceListeningConnector/RFI_INV_DRILLFORWARD_SERVICE.1.wsdl |
Y |
rfiInvoiceDrillForwardServiceEndPointUserAlias |
RFI Invoice drill forward service EndPointUser Alias. Constant at rfiInvoiceDrillForwardServiceEndPointUserAlias. |
N |
rfiInvoiceDrillForwardServiceEndPointUser |
RFI Invoice drill forward service EndPoint Username. |
GET_FROM_WALLET |
N |
rfiInvoiceDrillForwardServiceEndPointPassword |
RFI Invoice drill forward service EndPoint Username Password. |
GET_FROM_WALLET |
N |
rfiInvoiceDrillForwardServiceEndPointSecurityPolicyName |
unsecure |
Y |
rfiInvoiceDrillForwardServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias |
RFI Invoice drill forward service EndPoint WebserviceKeyStore Password User alias. |
N |
rfiInvoiceDrillForwardServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias |
RFI Invoice drill forward service EndPoint Web service Keyprivate key alias. |
N |
RfiBulkServer |
N |
odiHost |
Odihostname |
Y |
odiUrl |
Y |
odiUserAlias |
N |
odiUser |
ODI User Name. |
GET_FROM_WALLET |
N |
odiPassword |
GET_FROM_WALLET |
N |
odiAgentHost |
ODI agent host name. Name of the machine where ODI agent is installed. |
odihostname |
Y |
odiAgentPort |
20910 |
Y |
Table B-4 Cloud Financials – JSON Configuration
integrationToEbsOrPsft OrCfin |
CFIN |
N |
DataSourceDef |
RmsDataSource |
dataSourceName |
RmsDataSource |
N |
dataSourceClass |
N |
N |
jdbcUrl |
jdbc:oracle:thin:@//rmsdbhost.ex ample.com:1521/orcl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
RfiDataSource |
dataSourceName |
RfiDataSource |
N |
dataSourceClass |
oracle.jdbc.xa.client.OracleXADat aSource |
N |
N |
jdbcUrl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
RfiDataSource |
dataSourceName |
RfiDataSource |
N |
dataSourceClass |
N |
N |
jdbcUrl |
jdbc:oracle:thin:@//rfidbhost.exa mple.com:1521/orcl |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
dataSourceName |
N |
dataSourceClass |
N |
N |
jdbcUrl |
jdbc:oracle:thin:@//odimasterhos tname.us.custom.com:1521/plgdb |
Y |
jdbcUserAlias |
N |
jdbcUser |
User (schema name) for the ODImaster repository database. |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
OdiWorkDataSource |
dataSourceName |
OdiWorkDataSource |
N |
N |
jdbcUrl |
jdbc:oracle:thin:@//odiworkhost name.us.custom.com:1521/plgdb |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
OdiStagingAreaDataSou rce |
dataSourceName |
N |
dataSourceClass |
N |
N |
jdbcUrl |
jdbc:oracle:thin:@//odistagingho stname.us.custom.com:1521/plgd b |
Y |
jdbcUserAlias |
N |
jdbcUser |
GET_FROM_WALLET |
N |
jdbcPassword |
GET_FROM_WALLET |
N |
RfiAppServer |
RFIDomain |
Y |
RFI domain home. |
Y |
WebLogic domain admin serverURL. |
Y |
t3 |
N |
Y |
19301 |
Y |
rfiAppServerAdminServerUserAl ias |
N |
Weblogic Domain TargetManaged Server name. |
rfi-server |
Y |
glAccountValidationServ iceEndPointUrl |
http://myhostname:7001/GlAcc ountValidationBean/GlAccountV alidationService?WSDL |
Y |
glAccountValidationServ iceEndPointUserAlias |
N |
glAccountValidationServ iceEndPointUser |
GET_FROM_WALLET |
N |
glAccountValidationServ iceEndPointPassword |
GET_FROM_WALLET |
N |
glAccountValidationServ iceEndPointSecurityPoli cyName |
unsecure |
Y |
drillBackForwardUrlSer viceEndPointUrl |
http://myhostname:7001/DrillBa ckForwardUrlBean/DrillBackFor wardUrlService?WSDL |
Y |
http://myhostname:7001/fin-Dri llBackForwardUrl-AppServiceDe corator/ProxyService/DrillBackF orwardUrlAppServiceProxy?wsdl |
Y |
supplierExportOutboundServiceEndPointUrl |
URL information that will be used in connection for Supplier Export Outbound Service. |
http://myhostname:7001/Suppli erExportOutboundService/Su pplierExportOutboundServi ce?WSDL |
Y |
supplierExportOutboundServiceEndPointU serAlias |
User Alias. Constant at Supplier Export Outbound Service User Alias. |
supplierExportOutboundSe rviceEndPointUserAlias |
N |
supplierExportOutboundServiceEndPointUser |
Supplier Export OutboundService User name. |
GET_FROM_WALLET |
N |
supplierExportOutboundServiceEndPointP assword |
Supplier Export OutboundService End point User password. |
GET_FROM_WALLET |
N |
supplierExportOutboundServiceEndPointS ecurityPolicyName |
unsecure |
Y |
invoiceEntryInputDirectory |
Directory to place ODI created csv files that will be imported for Cfin regarding Invoice Entry |
/directory/example |
Y |
rmsAccountEntryInputDirectory |
Directory to place ODI created csv files that will be imported for Cfin regarding RMS Acco unt Entry |
Y |
reimAccountEntryInputDirectory |
Directory to place ODI created csv files that will be imported for Cfin regarding ReIM Account Entry |
Y |
rfiAdminUiUrl |
http://myhostname:7001/retail-f inancial-integration-web |
Y |
RfiAdminGroup |
N |
N |
rfiAdminUiUser |
GET_FROM_WALLET |
N |
GET_FROM_WALLET |
N |
smtpServerHost |
smtp.example.com |
Y |
smtpServerPort |
465 |
Y |
SSL |
N |
smtpAuthenticationReq uired |
TRUE |
Y |
Y |
N |
GET_FROM_WALLET |
N |
Comma separated list of recipient email addresses. |
receiver_email_address@abc.com, receiver_email_ address2@abc.com |
Y |
IgsAppServer |
http://igshostname:19201/CurRa tePublishingBean/CurRatePublis hingService?wsdl |
Y |
http://igshostname:19201/igs-C urRatePublishing-AppServiceDec orator/ProxyService/CurRatePu blishingAppServiceProxy?wsdl |
Y |
currencyRateServiceEndPointUse rAlias |
N |
GET_FROM_WALLET |
N |
GET_FROM_WALLET |
N |
currencyRateServiceEnd PointSecurityPolicyNam e |
unsecure |
Y |
currencyRateServiceEnd PointPolicyBSecurityPoli cy.wsKeystorePassword UserAlias |
currencyRate#keystore-password- user-alias |
N |
currencyRateServiceEnd PointPolicyBSecurityPoli cy.wsKeyPublicPrivateK eyAlias |
currencyRate#remote-host-public- private-key-alias |
N |
RmsAppServer |
http://rmshostname.example.co m:19203/SupplierBean/SupplierS ervice?WSDL |
Y |
http://rmshostname.example.co m:19203/rms-Supplier-AppServic eDecorator/ProxyService/Suppli erAppServiceProxy?wsdl |
Y |
supplierServiceEndPointUserAlia s |
N |
GET_FROM_WALLET |
N |
GET_FROM_WALLET |
N |
unsecure |
Y |
supplierServiceEndPoint PolicyBSecurityPolicy.ws KeystorePasswordUserA lias |
supplier#keystore-password-user- alias |
N |
supplierServiceEndPoint PolicyBSecurityPolicy.ws KeyPublicPrivateKeyAli as |
supplier#remote-host-public-priv ate-key-alias |
N |
CfinAppServer |
Cfin App Server Configuration Details |
financialUtilServiceEndPointUrl |
Cfin Financial Util Service End Point URL |
https://cfinhostname/finFunShared/FinancialUtilService?WSDL |
Y |
financialUtilServiceEndPointUserAlias |
Cfin Financial Util Service User Alias |
financialUtilServiceUserNameAlias |
N |
financialUtilServiceEndPointUser |
UserName for Financial Util Service End point User. |
GET_FROM_WALLET |
N |
financialUtilServiceEndPointPassword |
Password for Financial Util Service service. |
GET_FROM_WALLET |
N |
financialUtilServiceEndPointSecurityPolicyName |
unsecure |
Y |
glAccountValidationEndPointUrl |
Cfin General Ledger Validation Service End Point URL |
https://cfinhostname/fscmService/AccountCombinationService?WSDL |
Y |
glAccountValidationEndPointUserAlias |
Cfin General Ledger Validation Service User Alias |
N |
glAccountValidationEndPointUser |
UserName for General Ledger Validation Service End point User. |
GET_FROM_WALLET |
N |
glAccountValidationEndPointPassword |
Password for General Ledger Validation Service service |
GET_FROM_WALLET |
N |
glAccountValidationEndPointSecurityPolicyName |
unsecure |
Y |
RfiBulkServer |
N |
odiHost |
Odihostname |
Y |
odiUrl |
Path in machine name (odihostname), where ODI is installed. |
Y |
odiUserAlias |
N |
odiUser |
ODI User Name. |
GET_FROM_WALLET |
N |
odiPassword |
GET_FROM_WALLET |
N |
odiAgentHost |
odihostname |
Y |
odiAgentPort |
20910 |
Y |
