Go to primary content
Oracle® Retail Bulk Data Integration Cloud Service Implementation Guide – Concepts
Release 22.1.302.0
F60976-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
A Process Schema
The process instrumentation captures the state of the process at the beginning and end of each activity. This information is persisted into the process schema. For each activity there will be two records, one for before activity and the other for after activity.
Table Name Description
BDI_PROCESS_DEFINITION This table stores all the process flow definitions. It is loaded at deployment time.
BDI_PROCESS_EXEC_INSTANCE This table tracks all the process flow executions. There is a row for each process flow execution.
BDI_ACTIVITY_EXEC_INSTANCE This table tracks all the activity executions. There are 2 rows for each activity execution. One to store the before context and one to store after context
BDI_ACTIVITY_DYNAMIC_CONFIG This table stores the user runtime choices like SKIP, HOLD etc at activity level
BDI_SYSTEM_OPTIONS This table has all the system level information like URLs, credential aliases etc.
BDI_EMAIL_NOTIFICATION This table persists all the process email notifications.
BDI_PROCESS_CALL_STACK This table stores call stack for processes.
BDI_EXTERNAL_VARIABLE This table does temporary storage of variables during process execution.
BDI_GROUP This table stores group names and its attributes
BDI_GROUP_LOCK This table stores the lock id and group names
BDI_GROUP_MEMBER This table stores all group member details
Column Type Comments
PROCESS_NAME VARCHAR2(255) Name of the process
PROCESS_ENABLE_STATUS VARCHAR2(255) Enable or disable the process (true or false)
PROCESS_CREATE_TIME TIMESTAMP Timestamp when the process was loaded to database
PROCESS_DEF_CONTENT CLOB The Process Flow DSL
ACTIVITY_EXEC_ID VARCHAR2(255) System generated id for activity instance
ACTIVITY_BEGIN_OR_END VARCHAR2(255) "B" for Before Image, "A" for after image
ACTIVITY_EVENT_TIME TIMESTAMP Time when he activity occurred
ACTIVITY_NAME VARCHAR2(255) Name of the activity
ACTIVITY_SEQ_NBR NUMBER Sequence number of the activity
ACTIVITY_STATUS NUMBER Activity Status
PROCESS_EXECUTION_ID VARCHAR2(255) Process Execution Id of the process instance that initiated the activity
PROCESS_VARIABLES BLOB Serialized process variable map
PROCESS_EXECUTION_ID VARCHAR2(255) Process Execution Id of the process instance that initiated the activity.
PROCESS_EXEC_START_TIME TIMESTAMP Time when the process execution started
PROCESS_EXEC_END_TIME TIMESTAMP Time when the process execution started
PROCESS_FIRST_RUN_START_TIME TIMESTAMP Time when the process execution started, does not change when process is restarted.
PROCESS_STATUS VARCHAR2(255) Process status
HOLD_FLAG VARCHAR2(255) To hold the activity
SKIP_FLAG VARCHAR2(255) To skip the activity
SKIP_OR_HOLD_EXPIRATION TIMESTAMP Time when skip or hold activity expires.
COMMENTS VARCHAR2(255) Comments
INVOKE_CALLBACK_SERVICE VARCHAR2(255) Invoke any callback service
USER_NAME VARCHAR2(255) Username
CALLBACK_SERVICE_URL_ALIAS VARCHAR2(255) Callback Service URL Alias
CALLBACK_SERVICE_URL VARCHAR2(255) Callback Service URL
EMAIL_NOTIFICATION_ID NUMBER Process Execution Id of the process instance that initiated the activity
APP_NAME VARCHAR2(100) Name of the application
EMAIL_NOTIFICATION_TO VARCHAR2(500) EMail Ids to whom notification will be sent
EMAIL_NOTIFICATION_SUBJECT CLOB Notification subject
EMAIL_NOTIFICATION_CONTENT CLOB Notification content
EMAIL_NOTIFICATION_DATETIME TIMESTAMP At what time notification sent
EMAIL_NOTIFICATION_TYPE VARCHAR2(255) Type of information
ACTION_STATUS VARCHAR2(255) status (PENDING/COMPLETED)
COMMENTS VARCHAR2(500)
BDI_SYSTEM_OPTIONS
CREATE_TIME TIMESTAMP Time it was created
UPDATE_TIME TIMESTAMP Time it was updated
VARIABLE_NAME VARCHAR2(255) Name of system variable
APP_TAG VARCHAR2(255) The application name
VARIABLE_VALUE VARCHAR2(255) Value of the variable
