This tutorial describes how to create and deploy an application that tracks the assignment, status, and progress of issues related to a project. This tutorial walks you through all the steps necessary to create a robust issue tracking application, including planning the project, creating the underlying database objects, loading demonstration data, and building a rich user interface.
This tutorial takes approximately four to five hours to complete. It is recommended that you read through the entire document first to become familiar with the material before you attempt specific exercises.Topics in this section include:
Effective project management is the key to completing any project on time and within budget. Within every project there are always multiple issues that need to be tracked, prioritized, and managed.
In this business scenario, MRVL Company has several projects that must be completed on time for the company to be profitable. Any missed project deadlines will result in lost revenue. The company's project leads use various methods to track issues, including manually recording statuses in notebooks, organizing issues in text documents, and categorizing issues by using spreadsheets.
By creating a hosted application in Oracle Application Express, project leads can easily record and track issues in one central location. This approach offers each project lead access to just the data they need and makes it easier for management to determine if critical issues are being addressed.
Before beginning development on an Oracle Application Express application, you first need to define application requirements. Then, you use the defined requirements to design a database and an outline that describes how the user interface accepts and presents data.
For this business scenario, the project leads establish requirements that define the information that must be tracked, security requirements, data management functions, and how to present data to users.
Currently, each project lead tracks information slightly differently. Together, everyone agrees that the application should include the following information:
Summary of the issue
Detailed description of the issue
Who identified the issue
The date on which the issue was identified
Which project the issue is related to
Who the issue is assigned to
A current status of the issue
Priority of the issue
Target resolution date
Actual resolution date
Progress report
Resolution summary
Because the project leads are concerned about everyone having access to all the information, they agree upon the following access rules:
Each team member and project lead is only assigned to one project at a time
Each team member and project lead must be assigned to a project
Managers are never assigned to a specific project
Only managers can define and maintain projects and people
Everyone can enter new issues
Once assigned, only the person assigned or a project lead can change data about the issue
Management needs views that summarize the data without access to specific issue details
Next, the project leads determine how information will be entered into the system. For this project, users must be able to:
Create issues
Assign issues
Edit issues
Create projects
Maintain projects
Create people
Maintain people information
Maintain project assignments
Once the data is entered into the application, users need to view the data. The team decides that users must be able to view the following:
All issues by project
Open issues by project
Overdue issues, by project and for all
Recently opened issues
Unassigned issues
Summary of issues by project, for managers
Resolved issues by month identified
Issue resolution dates displayed on a calendar
Days to Resolve Issues by person
Finally, the project leads determine that the application must support the following special functions:
Notify people when an issue is assigned to them
Notify the project lead when any issue becomes overdue
Once you have defined the database requirements, the next step is to turn these requirements into a database design and an outline that describes how the user interface accepts and presents data. In this step you need to think about how information should be organized in the tables in the underlying database. Given the requirements described "Planning and Project Analysis", for this project you need to create three tables:
Projects
tracks all current projects
People
contains information about who can be assigned to handle issues
Issues
tracks all information about an issue, including the project to which it is related and the person assigned to the issue
In addition to the tables, you also need to create additional database objects, such as sequences and triggers, to support the tables. System generated primary keys will be used for all tables so that all the data can be edited without executing a cascade update.
Each project must include project name, project start date, target date, and actual end date columns. These date columns help determine if any outstanding issues are jeopardizing the project end date. Table 14-1 describes the columns to be included in the Projects table.
Table 14-1 Project Table Details
Column Name | Type | Size | Not Null? | Constraints | Description |
project_id |
integer |
n/a |
Yes |
Primary key |
A unique numeric identification for each project. Populated by a sequence using a trigger. |
project_name |
varchar2 |
100 |
Yes |
Unique key |
A unique alphanumeric name for the project. |
start_date |
date |
n/a |
Yes |
None |
The project start date. |
target_end_date |
date |
n/a |
Yes |
None |
The targeted project end date. |
actual_end_date |
date |
n/a |
No |
None |
The actual end date. |
Each person will have a defined name and role. Project leads and team members will also have an assigned project. To tie the current user to their role within the organization, email addresses will be used for user names.
Table 14-2 describes the columns that will be included in the People table.
Table 14-2 People Table Details
person_id |
integer |
n/a |
Yes |
Primary key |
A numeric ID that identifies each user. Populated by a sequence using a trigger. |
person_name |
varchar2 |
100 |
Yes |
Unique key |
A unique name that identifies each user. |
person_email |
varchar2 |
100 |
Yes |
None |
User email address. |
person_role |
varchar2 |
7 |
Yes |
Check constraint |
The role assigned to each user. |
For the purposes of this exercise, this application has been simplified. User data is usually much more elaborate and is often pulled from a corporate Human Resource system. Also, users typically work on more than one project at a time. If the roles that are assigned to a user need to be dynamic, you would implement roles as a separate table with a foreign key that relates to the people table.When the project leads defined their application requirements, they decided to track separate issues assigned to each person. Issues will be included in columns along with additional columns to provide an audit trail. The audit trail will track who created the issue, when it was created, as well as who modified the issue last and on what date that modification was made.
Table 14-3 describes the columns to be included in the Issues table.
Table 14-3 Issue Table Details
issue_id |
integer |
n/a |
Yes |
primary key |
A unique numeric ID that identifies an issue. Populated by a sequence using a trigger. |
issue_summary |
varchar2 |
200 |
Yes |
None |
A brief summary of the issue. |
issue_description |
varchar2 |
2000 |
No |
None |
A detailed description of the issue. |
identified_by |
integer |
n/a |
Yes |
foreign key to People |
The user who identifies the issue. |
identified_date |
date |
n/a |
Yes |
None |
The date the issue was identified |
related_project |
integer |
n/a |
Yes |
foreign key to Projects |
Projects related to the issue. |
assigned_to |
integer |
n/a |
No |
The person who owns this issue. |
status |
varchar2 |
8 |
Yes |
check constraint |
The issue status. Automatically set to |
priority |
varchar2 |
6 |
No |
check constraint |
The priority of the issue. |
target_resolution_date |
date |
n/a |
No |
None |
The target resolution date. |
progress |
varchar2 |
2000 |
No |
None |
The progress of the issue. |
actual_resolution_date |
date |
n/a |
No |
None |
Actual resolution date of the issue. |
resolution_summary |
varchar2 |
2000 |
No |
None |
Resolution summary. |
created_date |
date |
n/a |
Yes |
None |
Populated by a trigger. |
created_by |
varchar2 |
60 |
Yes |
None |
User who created this issue. |
last_modified_date |
date |
n/a |
No |
None |
A real-world application might need more extensive auditing. For example, you might need to track each change to the data rather than just the last change. Tracking each change to the data would require an additional table, linked to the issues table. If the valid priorities assigned to issues need to be dynamic, you would be required to add a separate table with a foreign key that relates to the issues table.This first step in building an application is to create the database objects.
There are several ways to create objects in Oracle Application Express. You can:
Create an Object in Object Browser. Use Object Browser to create tables, views, indexes, sequences, types, packages, procedures, functions, triggers database links, materialized views, and synonyms. A wizard walks you through the choices necessary to create the selected database object. To create an object in Object Browser, navigate to SQL Workshop, then Object Browser, and click Create. See "Managing Database Objects with Object Browser" in Oracle Database Application Express User's Guide.
Execute SQL Commands. Run SQL Commands by typing or pasting them into the SQL Commands. To access SQL Commands, click the SQL Workshop icon on Workspace home page and then click SQL Commands. See "Using SQL Commands" in Oracle Database Application Express User's Guide.
Upload a script. Upload a script to the SQL Script Repository that contains all the necessary create object statements. To upload a script, click SQL Workshop on the Workspace home page, click SQL Scripts and then click Upload. See "Uploading a SQL Script" in Oracle Database Application Express User's Guide.
Create script online. Create a script online in the Script Repository. You will use this method to create database objects for this exercise. To create a script online, click the SQL Workshop icon on the Workspace home page, select SQL Scripts and then click Create. See "Creating a SQL Script in the Script Editor" in Oracle Database Application Express User's Guide.
For this exercise, you create and run a script.
To build database objects by creating a script:
Log in to Oracle Application Express.
On the Workspace home page, click SQL Workshop and then SQL Scripts.
Click Create.
In the Script Editor:
For Script Name, enter DDL for Issue Management Application
Copy the data definition language (DDL) in "Creating Application Database Objects DDL" and paste it into the script.
Click Save.
On the SQL Scripts page, click the DDL for Issue Management Application icon.
The Script Editor appears.
Click Run.
A summary page appears.
Click Run again.
The Manage Script Results page displays a message that the script has been submitted for execution.
You can view database objects using Object Browser.
To view database objects in Object Browser:
Return to the Workspace home page. Click the Home breadcrumb link.
On the Workspace home page, click SQL Workshop and then Object Browser.
From the Object list on the left side of the page, select Tables.
To view the details of a specific object, select one of the following tables:
HT_ISSUES
HT_PEOPLE
HT_PROJECTS
See Also:
"Managing Database Objects with Object Browser" in Oracle Database Application Express User's Guide.Once you have created all the necessary database objects, the next step is to load data into the tables. You can manually load data using the import functionality available in SQL Scripts. In the following exercise, however, you use SQL Scripts to load demonstration data.
Look at the DDL you copied from "Creating Application Database Objects DDL". Notice that the sequences used for the primary keys start at 40 in order to leave room for the demonstration data. The BEFORE INSERT
triggers are coded so that the sequence is only accessed if a primary key value is not provided: they will not need to be disabled in order for you to load data.
To import data into the Projects table:
Click the SQL Workshop breadcrumb link.
Click SQL Scripts.
Click Create.
In the Script Editor, specify the following:
Script Name - Enter Load Project Data
Script - Copy and paste the following:
INSERT INTO ht_projects (project_id, project_name, start_date, target_end_date) VALUES (1, 'Internal Infrastructure', sysdate-150, sysdate-30) / INSERT INTO ht_projects (project_id, project_name, start_date, target_end_date) VALUES (2, 'New Payroll Rollout', sysdate-150, sysdate+15) / INSERT INTO ht_projects (project_id, project_name, start_date, target_end_date) VALUES (3, 'Email Integration', sysdate-120, sysdate-60) / INSERT INTO ht_projects (project_id, project_name, start_date, target_end_date) VALUES (4, 'Public Website Operational', sysdate-60, sysdate+30) / INSERT INTO ht_projects (project_id, project_name, start_date, target_end_date) VALUES (5, 'Employee Satisfaction Survey', sysdate-30, sysdate+60) /
Click Save.
On the SQL Scripts page, click the Load Project Data icon.
Click Run.
Click Run again.
Although you have created the projects, the dates need to be updated to make the projects current. To accomplish this, you run another script.
To update the project dates and make the projects current:
Click the SQL Scripts breadcrumb link.
Click Create.
Script Name - Enter Update Project Dates
In Script, copy and paste the following:
UPDATE ht_projects SET start_date = sysdate-150, target_end_date = sysdate-30 WHERE project_id = 1 / UPDATE ht_projects SET start_date = sysdate-150, target_end_date = sysdate+15 WHERE project_id = 2 / UPDATE ht_projects SET start_date = sysdate-120, target_end_date = sysdate-60 WHERE project_id = 3 / UPDATE ht_projects SET start_date = sysdate-60, target_end_date = sysdate+30 WHERE project_id = 4 / UPDATE ht_projects SET start_date = sysdate-30, target_end_date = sysdate+60 WHERE project_id = 5 /
Click Save.
On the SQL Scripts page, click the Update Project Dates icon.
Click Run.
Click Run again.
After you have loaded data into the Project table, you can load People data. Because of foreign keys in the Projects table, People data must be loaded after Project data. You load data into the People table by creating and running a script in SQL Workshop.
To load data into the People table:
On the SQL Scripts page, click Create.
Script Name - Enter Load People Data
INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (1, 'Joe Cerno', 'joe.cerno@mrvl-bademail.com', 'CEO', null) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (2, 'Kim Roberts', 'kim.roberts@mrvl-bademail.com', 'Manager', null) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (3, 'Tom Suess', 'tom.suess@mrvl-bademail.com', 'Manager', null) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (4, 'Al Bines', 'al.bines@mrvl-bademail.com', 'Lead', 1) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (5, 'Carla Downing', 'carla.downing@mrvl-bademail.com', 'Lead', 2) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (6, 'Evan Fanner', 'evan.fanner@mrvl-bademail.com', 'Lead', 3) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) values (7, 'George Hurst', 'george.hurst@mrvl-bademail.com', 'Lead', 4) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (8, 'Irene Jones', 'irene.jones@mrvl-bademail.com', 'Lead', 5) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (9, 'Karen London', 'karen.london@mrvl-bademail.com', 'Member', 1) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) values (10, 'Mark Nile', 'mark.nile@mrvl-bademail.com', 'Member', 1) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (11, 'Jane Kerry', 'jane.kerry@mrvl-bademail.com', 'Member', 5) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (12, 'Olive Pope', 'olive.pope@mrvl-bademail.com', 'Member', 2) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (13, 'Russ Sanders', 'russ.sanders@mrvl-bademail.com', 'Member', 3) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (14, 'Tucker Uberton', 'tucker.uberton@mrvl-bademail.com', 'Member', 3) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (15, 'Vicky Williams', 'vicky.willaims@mrvl-bademail.com', 'Member', 4) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (16, 'Scott Tiger', 'scott.tiger@mrvl-bademail.com', 'Member', 4) / INSERT INTO ht_people (person_id, person_name, person_email, person_role, assigned_project) VALUES (17, 'Yvonne Zeiring', 'yvonee.zeiring@mrvl-bademail.com', 'Member', 4) /
Click Save.
On the SQL Scripts page, click the Load People Data icon.
Click Run.
Click Run again.
The last data you need to load is the Issues data. As with People data, you create and run a script to populate the Issues
table.
To load data into the Issues
table:
Click Create.
Script Name - Enter Load Issue Data
Script - Copy and paste the script in "Creating Issues Script".
Click Save.
On the SQL Scripts page, click the Load Issue Data icon.
Click Run.
Click Run again.
After you create the objects that support your application and load the demonstration data, the next step is to create a user interface. In this exercise, you use the Create Application Wizard in Application Builder to create an application and then the pages that support the data management and data presentation functions described in "Planning and Project Analysis".
You use the Create Application Wizard to create an application containing pages that enable users to view reports on and create data for the selected tables within a schema. Alternatively, you can create an application first and then add pages to it. As the application requirements include customized overview pages, for this exercise you will use the latter approach.
To create the application:
On the Workspace home page, click Application Builder.
Click Create.
For Method, select Create Application and then click Next.
For Name:
Name - Enter Issue Tracker
Create Application - Select From scratch.
Click Next.
Next, add a blank page. Under Add Page:
Under Select Page Type, select Blank.
Click Add Page.
Click Next.
For Tabs, select No Tabs and then click Next.
For Shared Components, accept the default, No, and click Next.
For Attributes, accept the defaults for Authentication Scheme, Language, and User Language Preference Derived From and click Next.
For User Interface, select Theme 10 and click Next.
Click Create.
To view the application:
Click the Run Application icon on the Applications home page.
When prompted, enter your workspace user name and password and then click Login. See "About Application Authentication".
This authentication is part of the default security of any newly created application. As shown in Figure 14-1, the home page appears.
Figure 14-1 Issue Tracking Application Home Page
Although the page has no content, notice that the Create Application Wizard has created the following items:
Navigation Links - A navigation bar entry displays in the upper right of the page. Logout enables the user to log out of the application.
Developer Links - The Developer toolbar appears on the page. These links only display if you are logged in as a developer. Users who only have access to run the application cannot see these links.
Click Application on the Developer toolbar to return to the Application home page.
Notice that the Create Application Wizard also created a Login page.
Once you have created the basic application structure, the next step is to create individual pages.
First, you need to create pages that enable users to view and add data to tables. To accomplish this, you use the Form on a Table with Report Wizard. This wizard creates a report page and maintenance page for each table.
To create pages for maintaining the HT_PROJECTS
table:
On the Application home page, click Create Page.
Select Form and then click Next.
Select Form on a Table with Report and click Next.
For Table/View Owner, select the appropriate schema and then click Next.
For Table/View Name, select HT_PROJECTS
and click Next.
For Define Report Page:
Page Number: Enter 2
Page Name and Region Title - Enter Projects
Accept the remaining defaults and click Next.
For Tab Options, accept the default, Do not use tabs, and then click Next.
For Select Column(s), select all columns except PROJECT_ID
Note that Project Name is unique and identifies the project. The ID was added to simplify the foreign key and enable cascading updates.
For Edit Link Image, select the fourth option (the word Edit) and then click Next.
For Define Form Page:
Page - Enter 3
Page Name and Region Title - Enter Create/Edit Project
Click Next.
For Tab Options, accept the default, Do not use tabs, and click Next.
For Primary Key, accept the default, PROJECT_ID and click Next.
For Source Type, accept the default, Existing Trigger, and click Next.
For Select Column(s), select all columns and click Next.
Under Identify Process Options, accept the defaults for Insert, Update and Delete, and click Next.
Review your selections and click Finish.
Click the Run Page icon.
As shown in Figure 14-2, the newly created report displays the demo data.
Click the Edit link to view an existing row or click the Create button to create a new record. If you click Edit to the left of Employee Satisfaction Survey, a form resembling Figure 14-3 appears.
You can change the appearance of the Projects report page by adding a format mask to the dates.
To add a format mask to the dates on the Create/Edit Project page:
Go to the Page Definition for page 2, Projects:
Click Application on the Developer toolbar.
On the Application home page, click 2 - Projects.
Under Regions, click Report next to Projects.
Edit the format for START_DATE
Click the Edit icon to the left of START_DATE
The Column Attributes page appears.
Under Column Formatting, for Number/Date Format, enter DD-MON-YYYY.
Edit the format for the TARGET_END_DATE
Click the Next button (>) at the top of the page to go to the next Report Item.
Edit the format for the ACTUAL_END_DATE
Click Apply Changes.
The Report Attributes page appears.
For PROJECT_ID
, delete the Heading Edit.
For the START_DATE
, TARGET_END_DATE
and ACTUAL_END_DATE
columns, select center for Column Alignment and Heading Alignment.
Next, enable users to sort on column headings.
To enable column heading sorting, check Sort for all columns except PROJECT_ID
For PROJECT_NAME
, select 1 for Sort Sequence.
This selection specifies PROJECT_NAME
as the default column to sort on. Note this functionality can be overridden by any user selections.
Scroll down to Sorting. For Ascending and Descending Image, select the light gray arrow.
Scroll down to Messages. In When No Data Found Message, enter the following:
No Projects found.
At the top of the page, click Apply Changes.
To view your changes, click the Run Page icon in the upper right of the page.
As shown in Figure 14-4, note the addition of a sort control on the Project Name column and the format of the dates in the Start Date and Target End Date columns.
Figure 14-4 Projects Page with Sort Control
Next, you need to customize the Create/Edit Project page to make the Project Name field larger and the date fields smaller. You also need to change the date picker type, add a format mask for dates, and add validations that check if the target and actual end dates are after the start date.
To make the Project Name field larger and the date fields smaller:
Go to the Page Definition for Page 3, Create/Edit Project:
From the Developer toolbar, click Application.
Click 3 - Create/Edit Project.
Under Items, click the Edit All icon.
The Edit All icon resembles a small grid with a pencil on top of it.
Scroll to the right and locate the Width column:
For Project Name, enter 60
For Start Date, enter 12
For Target End Date, enter 12
For Actual End Date, enter 12
Return to the Page Definition. Click the Edit Page icon in the upper right corner. The Edit Page icon resembles a small green piece of paper and pencil.
To change the date picker type and add a format mask for dates:
Edit the item P3_START_DATE
Under Items, click P3_START_DATE.
From the Display As list in the Name section, select Date Picker (DD-MON-YYYY).
Edit the item P3_TARGET_END_DATE
Under Items, select P3_TARGET_END_DATE.
Edit the item P3_ACTUAL_END_DATE
Under Items, select P3_ACTUAL_END_DATE.
Next, add validations to check if the target and actual end dates are after the start date.
To add validations:
Under Page Processing, Validations, click the Create icon.
For Level, accept the default Item level validation and click Next.
For Item, select Create/Edit Project: 40. P3_TARGET_END_DATE (Target End Date) and click Next.
For Validation Method, select PL/SQL and click Next.
Specify the type of validation you want to create. Accept the default PL/SQL Expression and click Next.
For Validation Name, enter TARGET_AFTER_START
and click Next.
For Validation:
Validation - Enter:
to_date(:P3_ACTUAL_END_DATE,'DD-MON-YYYY') >= to_date(:P3_START_DATE,'DD-MON-YYYY')
Error Message - Enter:
Actual End Date must be same or after Start Date.
Click Next.
For Conditions:
Condition Type - Select Value of Item in Expression 1 Is NOT NULL, or click the shortcut link [item not null].
Expression 1 - Enter:
P3_ACTUAL_END_DATE.
This selection ensures that this validation executes only if the user enters an Actual End Date.
Click Create.
To view your changes, click the Run Page icon in the upper right of the page. (See Figure 14-5.)
Once the initial Projects pages are complete, you create pages for maintaining people.
To create pages for maintaining the HT_PEOPLE
table:
Click Create Page.
Select Form and click Next.
For Table/View Owner, select the appropriate schema and click Next.
For Table/View Name, select HT_PEOPLE and click Next.
Page - Enter 4
Page Name and Region Title - Enter People
Click Next.
For Select Column(s), select all columns except PERSON_ID
and click Next.
For Edit Link Image, select the fourth option (the word Edit) and click Next.
Page Number - Enter 5
Page Name and Region Title - Enter Create/Edit Person Information
Click Next.
For Primary Key, accept the default, PERSON_ID, and click Next.
Specify the source for the primary key columns. Accept the default, Existing Trigger, and click Next.
For Select Column(s), select all the columns and click Next.
For Insert, Update and Delete, accept the defaults and click Next.
Review your selections and then click Finish.
To preview your page, click Run Page. As shown in Figure 14-6, notice the newly created report displays the demo data.
To preview the page for adding or editing people, click the Edit button in the far left column.
Next, you alter the People Report by changing the query to include a join to the Projects table and modify the headings.
To change the query to include a join to the Projects table:
Go to the Page Definition for page 4 - People:
If you are viewing a running form, click Application on the Developer toolbar.
On the Application home page, click 4 - People.
Under Regions, click People.
Scroll down to Source.
In Region Source, replace the existing query with the following:
SELECT a."PERSON_ID", a."PERSON_NAME", a."PERSON_EMAIL", a."PERSON_ROLE", b."PROJECT_NAME" FROM "#OWNER#"."HT_PEOPLE" a, "#OWNER#"."HT_PROJECTS" b WHERE a.assigned_project = b.project_id (+)
Note that the outer join is necessary because the project assignment is optional.
To modify the headings:
Click the Report Attributes tab at the top of the page.
Under Column Attributes, edit the following column headings:
PERSON_ID - Remove the Heading Edit.
PERSON_NAME - Change Heading to Name
PERSON_EMAIL - Change Heading to Email
PERSON_ROLE - Change Heading to Role
PROJECT_NAME - Change Heading to Assigned Project
and then select left for Heading Alignment.
Next, enable column heading sorting.
To enable column heading sorting:
Select Sort for all columns except PERSON_ID.
For PERSON_NAME
This selection specifies PERSON_NAME
as the default column to sort on. Note this functionality can be overridden by user selections.
Under Messages, enter the following in When No Data Found Message:
No people found.
Click Apply Changes at the top of the page.
To view your changes, click the Run Page icon in the upper right of the page. As shown in Figure 14-7, note the addition of a sort control on the Name column.
Next, you customize the Create/Edit People page by adding lists of values to make it easier for users to select a Role or Assigned Project.
To add a list of values for Projects:
Go to the Page Definition for page 5, Create/Edit Person:
If you are viewing a form, click Application on the Developer toolbar.
On the Application home page, click 5 - Create/Edit Person Information.
Under Shared Components, locate the Lists of Values section and then click the Create icon.
For Source, accept the default, From Scratch, and then click Next.
For Name and Type:
Name - Enter PROJECTS
Type - Select Dynamic.
Click Next.
In Query, replace the existing statements with the following:
SELECT project_name d, project_id v FROM ht_projects ORDER BY d
Click Create List of Values.
To add a list of values for Roles:
For Name and Type:
Name - Enter ROLES
Type - Select Static
Click Next.
Enter the display value and return value pairs shown in Table 14-4:
On the Lists of Values page, click the Edit Page icon in the upper right corner.
To edit display attributes for P5_PERSON_ROLE:
Under Items, click P5_PERSON_ROLE.
From the Display As list in the Name section, select Radiogroup.
Scroll down to Label.
Change Label to Role
Under Element, enter the following in Form Element Option Attributes:
class="instructiontext"
This specifies that the text associated with each radio group option is the same size as other items on the page.
Scroll down to List of Values.
From the Named LOV list, select ROLES.
To edit display attributes for P5_ASSIGNED_PROJECT
Under Items, click P5_ASSIGNED_PROJECT.
From the Display As list in the Name section, select Select List.
Under List of Values:
From the Named LOV list, select PROJECTS.
Next, specify that the underlying column is not mandatory.
For Null display value, enter:
- None -
To alter the display of fields and field labels:
For P5_PERSON_NAME
Prompt - Enter Name
Width - Enter 60
For P5_PERSON_EMAIL
Prompt - Enter Email Address
For Width, enter 60
Click the Edit Page icon in the upper right corner to return to the Page Definition for Page 5.
The Form on a Table with Report Wizard created not null validations for Name, Email, and Role. You must manually create another validation to ensure that Leads and Members have an assigned project while the CEO and Managers do not. As a best practice, it is generally best to use built-in validation types because they are faster. However, for this compound type of validation, you will write a PL/SQL validation.
To add validations to ensure the correct people are assigned projects:
For Level, accept the default, Item level validation, and click Next.
For Item, select Create/Edit Person Information: 50. P5_ASSIGNED_PROJECT (Assigned Project) and click Next.
For Validation Method:
Select PL/SQL and click Next.
Accept the default, PL/SQL Expression and click Next.
For Sequence and Name:
Validation Name - Enter PROJECT_MAND_FOR_LEADER_AND_MEMBER
For Validation and Error Message:
Validation - Enter:
(:P5_PERSON_ROLE IN ('CEO','Manager') AND :P5_ASSIGNED_PROJECT = '%'||'null%') OR (:P5_PERSON_ROLE IN ('Lead','Member') AND :P5_ASSIGNED_PROJECT != '%'||'null%')
Oracle Application Express passes nulls as %null%
. It also replaces %null%
with a null when it processes data. Therefore, to keep it in the validation, you need to break the string apart so that it is not recognized and replaced.
Leads and Members must have an Assigned Project. CEO and Managers cannot have an Assigned Project.
Click Next.
Click Create.
To view your changes, click the Run Page icon in the upper right of the page. The revised form appears as shown in Figure 14-8.
Figure 14-8 Revised Create/Edit Person Information Form
Try entering some records to test the validation. Enter a CEO with a project and then enter a Lead without a project. Both cases should fail and display the error message you defined.
Lastly, you need to create pages for HT_ISSUES
. This application needs multiple views on Issues. You can create these views as single reports or as separate reports. For this exercise, you create a complex report that includes an Issues maintenance form. You then link this maintenance form in multiple places. Ultimately, the Issues report will display Issues by the person who identified the issue, project, assigned person, status, or priority.
To create a report for maintaining HT_ISSUES
Click Create Page.
For Table/View Name, select HT_ISSUES and click Next.
On Define Report Page:
Page Number - Enter 6
Page Name and Region Title - Enter Issues
Click Next.
For Select Column(s):
Press CTRL to select the following columns:
ISSUE_SUMMARY
IDENTIFIED_BY
RELATED_PROJECT
ASSIGNED_TO
STATUS
PRIORITY
TARGET_RESOLUTION_DATE
ACTUAL_RESOLUTION_DATE
Click Next.
On Define Form Page:
Page Number - Enter 7
For Page Name and Region Title, enter Create/Edit Issues
Click Next.
For Primary Key, accept the default, ISSUE_ID, and click Next.
For Define the source for the primary key columns, accept the default, Existing Trigger, and click Next.
For Insert, Update and Delete, accept the default value, Yes, and click Next.
Click Edit Page.
You refine the Create/Edit Page for the following reasons:
Add lists of values to make it easier for users to select foreign key columns
Organize and clean up items
Change the display of audit columns
Add a button to make data entry faster
Next, you need to add lists of values for Status, Priorities, and People.
To add a list of values for Status:
Go to the Page Definition for page 7, Create/Edit Issues. On the Page Definition, enter 7 in the Page field and click Go.
Under Shared Components, Lists of Values, click the Create icon.
For Create List of Values, accept the default, From Scratch, and click Next.
On Create List of Values:
Name - Enter STATUS
For Type, select Static.
Click Next.
Enter the Display Value and Return Value pairs shown in Table 14-5:
To add a list of values for Priorities:
On the Lists of Values page, click Create.
Name - Enter PRIORITIES
Click Next.
Enter the Display Value and Return Value pairs shown in Table 14-6.
To add a list of values for People:
For Name, enter PEOPLE
For Type, select Dynamic.
Click Next.
SELECT person_name d, person_id v FROM ht_people ORDER BY 1
Go to the Page Definition for page 7.
Next, you edit individual items.
To edit P7_IDENTIFIED_BY
Under Items on the Page Definition for Page 7, click P7_IDENTIFIED_BY.
Named LOV - Select PEOPLE.
Display Null - Select Yes. The base column is mandatory, but you do not want the first name in the list becoming the default value.
Null display value - Enter:
- Select Person -
Click the Next button (>) at the top of the page to go to the next item, P7_IDENTIFIED_DATE
The Edit Page Item page appears.
To edit P7_IDENTIFIED_DATE
Scroll down to Default:
Default value - Enter:
to_char(sysdate,'DD-MON-YYYY')
Default Value Type - Select PL/SQL Expression.
Click the Next button (>) at the top of the page to go to the next item, P7_RELATED_PROJECT.
To edit P7_RELATED_PROJECT
Scroll down to List of Values. For List of Values:
Named LOV - Select PROJECTS.
Display Null- Select Yes.
- Select Project -
Click the Next button (>) at the top of the page until you go to P7_STATUS
To edit P7_STATUS
Under Label, enter the following in the Label field:
Status:
Under Element, enter the following in the Form Element Option Attributes field:
Under Default, enter Open
in the Default Value field.
Named LOV - Select STATUS.
Number of Columns - Enter 3.
This selection enables the three valid values to display side by side.
Click the Next button (>) at the top of the page to go to P7_PRIORITY
To edit P7_PRIORITY:
Priority:
in Default value.
Named LOV - Select PRIORITIES.
Number of Columns - Enter 4.
This selection reflects the fact there are three valid values plus the null value.
Null display value - Enter the following.
None-
Click the Next button (>) at the top of the page to go to P7_TARGET_RESOLUTION_DATE
To edit P7_TARGET_RESOLUTION_DATE
Click the Next button (>) at the top of the page until you go to P7_ACTUAL_RESOLUTION_DATE
To edit P7_ACTUAL_RESOLUTION_DATE
Currently all items are grouped into one large region. Displaying items in logical groups makes data entry easier for users. Therefore, you next create four new regions named Buttons, Progress, Resolution, and Audit Information. You also rename an existing region.
To create new regions to group items:
Under Regions, click the Create icon.
Select Multiple HTML and then click Next.
For the first row:
For Sequence, enter 5
For Title, enter Buttons
For Template, select Button Region without Title.
For the second row, in Title enter Progress
For the third row, in Title enter Resolution
For the fourth row, in Title enter Audit Information
Click Create Region(s).
Now that the new regions exist, rename the first region, Create/Edit Issues:
Under Regions, click Create/Edit Issues.
In Title, enter:.
Issue Identification
Next, move each item to the appropriate region. Note that you also need to modify some item widths.
To move items to the appropriate regions:
The Page Items summary page appears.
Under Region, select Progress for the following items:
P7_ASSIGNED_TO
P7_STATUS
P7_PRIORITY
P7_PROGRESS
Under Region, select Resolution for the following items:
P7_RESOLUTION_SUMMARY
Under Region, select Audit Information for the following items:
P7_CREATED_DATE
P7_CREATED_BY
P7_LAST_MODIFIED_DATE
P7_LAST_MODIFIED_BY
Under Width, make the following edits:
For P7_ISSUE_SUMMARY, enter 60
For P7_IDENTIFIED_DATE, enter 12
For P7_TARGET_RESOLUTION_DATE, enter 12
For P7_ACTUAL_RESOLUTION_DATE, enter 12
Click the Edit Page icon in the upper right to return to the Page Definition of Page 7.
To move buttons to the Button region:
Under Buttons, click the Edit All icon.
Under Region, select Buttons for all buttons.
Click the Edit Page icon in the upper right to return the Page Definition of Page 7.
Because the Audit columns should be viewable but not editable, you need to make them display only. In the following exercise, you create a condition for the Audit Information region. As a result, the Audit Information region displays when a user edits an existing issue, but does not appear when a user creates a new issue.
To create a condition for the Audit Information region.
Under Regions, click Audit Information.
Scroll down to Conditional Display.
From Condition Type, select Value of Item in Expression 1 is NOT NULL.
In Expression 1, enter the following:
P7_ISSUE_ID
Next, change the audit columns to display only.
To edit P7_CREATED_DATE
Under Items, click P7_CREATED_DATE.
From the Display As list in the Name section, select Display as Text (saves state).
Under Label:
For Label, enter:
Created Date:
For Template, select Optional Label with Help.
For HTML Table Cell Attributes, enter:
Under Source, enter the following in Format Mask:
DD-MON-YYYY
Click the Next button (>) at the top of the page to go to the next item, P7_CREATED_BY
To edit P7_CREATED_BY
Under Label:
For Label, enter:
Created By:
Click the Next button (>) at the top of the page to go to the next item, P7_LAST_MODIFIED_DATE
To edit P7_LAST_MODIFIED_DATE:
Under Label:
For Label, enter:
Last Modified Date:
DD-MON-YYYY
Click the Next button (>) at the top of the page to go to the next item, P7_LAST_MODIFIED_BY
To edit P7_LAST_MODIFIED_BY
Under Label:
For Label, enter:
Last Modified By:
The Form on a Table with Report Wizard created not null validations for Issue Summary, Identified By, Related Project, Status, Created Date, and Created By. Since the Audit columns are set by a trigger, you need to remove these validations.
To remove not null validations:
Delete P7_CREATED_DATE not null:
Under Page Processing, Validations, click P7_CREATED_DATE not null.
Click Delete.
Click OK to confirm your selection.
Delete P7_CREATED_BY not null:
Click Delete.
Because this Create/Edit page will be called from several places, when users finish with the display, they should return to the calling page. To accomplish this, you create an item and change the branch on the Create/Edit page. Every time the Create/Edit page is called, the item must be set with the number of the calling page.
To create a hidden item:
Under Items, click the Create icon.
For Select Item Type, select Hidden and click Next.
For Display Position and Name:
Item Name - Enter:
P7_PREV_PAGE
Region - Select Issue Identification.
Click Next.
Click Create Item.
The Page Definition for page 7 appears.
Next, edit the Cancel button.
To edit the Cancel button:
Under Buttons, click Cancel.
Scroll down to Optional URL Redirect.
In Page, enter:
&P7_PREV_PAGE.
Note the period at the end.
Next, edit the branch.
To edit the branch:
Under Branches, select the After Processing branch, Go to Page.
Under Action, enter the following in Page (be sure to include the period):
&P7_PREV_PAGE.
Next, you add functionality that enables users to add more than one issue at a time. To accomplish this, you first add a new button and then create a new branch.
To add a new button:
Under Buttons, click the Copy icon.
For Button to copy, click CREATE.
For Target Page, accept the default, 7, and click Next.
For New Button:
Button Name - Enter CREATE_AGAIN
Label - Enter Create and Create Another
Click Copy Button.
Functionally, the Copy Button currently works the same as the CREATE button. Next, create a branch that keeps the user on the Create page.
Note that this branch also resets P7_PREV_PAGE because the value of that item will be lost when the cache of the page is cleared. The sequence of this new branch will be 0. Setting the sequence to 0 makes the branch fire before the default branch but only when the Create and Create Another button is used.
To create a branch that keeps the user on the create page:
Under Page Processing, Branches, click the Create icon.
For Point and Type, accept the defaults and click Next.
For Target:
Page - Enter 7
Clear Cache - Enter 7
Set these items - Enter the following:
P7_PREV_PAGE
With these values - Enter the following (be sure to include the period):
&P7_PREV_PAGE.
Click Next.
For Branch Conditions:
Sequence - Enter 0.
When Button Pressed - Select CREATE_AGAIN.
Click Create Branch.
Under Branches, select the newly created branch, Go to Page, next to 7.
Under Action, select the include process success message check box.
To see the changes, click the Run Page icon. The new form appears as shown in Figure 14-9.
The branch you just created is looking for a value in P7_PREV_PAGE. Since the page was not called from another page, the value has not been set. You need to fix that next.
Next, you refine the Issues report page to support dynamic modification of the query. To accomplish this, you must:
Move the Create button to a new region and edit the label
Create new items that enable the user to restrict the query
Add a WHERE
clause to reference those new items
Alter the report column attributes to display each person's name and the project
Modify headings
To create a new region for the Create button:
Go to the Page Definition for page 6, Issues.
Select HTML and click Next.
Select HTML for region container and click Next.
For Display Attributes:
Title - Enter Buttons
Region Template - Select Button Region without Title.
Display Point - Select Page Template Body (2. items below region content).
Click Next.
Click Create Region.
To move the Create button to the Buttons region:
Under Buttons, click the Create link.
Under Name, enter the following in the Text Label/Alt field:
Add a New Issue
Under Displayed, select Buttons in the Display in Region field.
Under Optional URL Redirect:
Set These Items - Enter:
P7_PREV_PAGE
For With These Values, enter 6
Next, change the query to display the actual values for people and projects instead of the ID and then clean up the report display.
To edit column attributes for ISSUE_ID:
Under Regions, select Report next to Issues.
Click the Edit Icon to the left of ISSUE_ID.
Scroll down to Column Link. Under Column Link:
For Item 2, Name, enter:
P7_PREV_PAGE
For Item 2, Value, enter 6.
To edit column attributes for IDENTIFIED_BY
, RELATED_PROJECT
and ASSIGNED_TO
Click the Edit Icon to the left of IDENTIFIED_BY
Scroll down to Tabular Form Element. From Display As, select Display as Text (based on LOV, does not save state).
Scroll down to Lists of Values. From Named LOV, select PEOPLE.
Return to the top of the page and click the Next (>) icon.
The Column Attributes page for RELATED_PROJECT appears.
Scroll down to Lists of Values. Under List of Values:
Null Text - Enter a hyphen (-).
The Column Attributes page for ASSIGNED_TO appears.
Next, you customize how the report displays by changing report attributes.
To alter the report display:
From Headings Type (the radiogroup row at the top of Column Attributes), accept the default, Custom.
For ISSUE_ID, delete the Heading text.
For ISSUE_SUMMARY, change the Heading to Summary
For TARGET_RESOLUTION_DATE:
Force the heading to wrap. In Heading, enter:
Target<br>Resolution<br>Date
For Column Alignment, select center.
For Heading Alignment, select center.
To sort on ISSUE_ID:
For all columns except ISSUE_ID, check Sort.
For ISSUE_SUMMARY, select 1 for Sort Sequence.
Scroll down to Layout and Pagination. Specify the following:
Show Null Values as - Enter a hyphen (-).
Number of Rows - Enter 5
Under Sorting, select the light gray arrow for Ascending and Descending Image.
No issues found.
Although the report now displays nicely, it does not support filtering by the end user. To add this functionality, you first create items that enable the user to set values to query against. You will store these new items in a new region that will display above the report.
To create a new region:
Select HTML and then click Next.
For Title, enter Issue Report Parameters
For Region Template, accept the default, Reports Region.
Click Next.
Next, create the items.
To create the item for Identified By:
For Select Item Type, select Select List and click Next.
For Select List Control Type, accept the default selection, Select List, and click Next.
For Item Name - Enter P6_IDENTIFIED_BY
For Region, select Issue Report Parameters.
Click Next.
For Identify List of Values:
For Named LOV, select PEOPLE.
For Null Text, enter:
- All -
For Null Value, enter:
-1
Click Next.
For Item Attributes, accept the defaults and click Next.
For Source, Default, enter:
-1
Click Create Item.
To create an item for Assigned To:
For Item Name, enter P6_ASSIGNED_TO
Click Next.
For Null Text - Enter:
- All -
For Null Value - Enter:
-1
Click Next.
-1
Click Create Item.
To create an item for Status:
For Select List Control Type, accept the default selection, Select List, and then click Next.
Item Name - Enter P6_STATUS
For Region - Select Issue Report Parameters.
Click Next.
For Named LOV - Select STATUS.
- All -
-1
Click Next.
-1
Click Create Item.
To create an item for Priority:
For Identify Item Name and Display Position:
For Item Name - Enter P6_PRIORITY
Click Next.
For List of Values:
For Named LOV - Select PRIORITIES.
- All -
-1
Click Next.
For Identify Item Attributes, accept the defaults and click Next.
For Source, for Default, enter:
-1
Click Create Item.
To create an item for Related Project:
For Select List Control Type, accept the default selection, Select List and click Next.
For Item Name - Enter P6_RELATED_PROJECT
Click Next.
For Named LOV - Select PROJECTS.
- All -
-1
Click Next.
-1
Click Create Item.
Next, create a Go button. This button enables the user to execute the query once they select report parameters. Buttons can be created in region positions or displayed among items.
To create Go button:
Under Buttons, click the Create icon.
For Button Region, select Issue Report Parameters and click Next.
For Button Position, select Create a button displayed among this region's items.
This selection displays the button to the right of the last report parameter.
Click Next.
For Button Attributes:
Button Name - Enter P6_GO
Button Style - Select Template Based Button.
Template - Select Button.
Click Create Button.
The Page Definition for page 6 appears.
Currently the items display stacked on top of one another. To use space more efficiently, change the position of P6_RELATED_PROJECT, P6_STATUS, and P6_PRIORITY so they display next to each other. Place P6_RELATED_PROJECT, P6_STATUS on the first line and P6_PRIORITY on the second line.
To change the position of P6_RELATED_PROJECT, P6_STATUS, and P6_PRIORITY:
For P6_RELATED_PROJECT, P6_STATUS, and P6_PRIORITY, select No for New Line.
Click the Edit Page icon in the upper right corner to return to the Page Definition for page 6. The Edit Page icon resembles a small green piece of paper and pencil.
Next, you need to modify the report to react to the parameters. To accomplish this, you need to modify the query's WHERE
clause as follows:
WHERE (IDENTIFIED_BY = :P6_IDENTIFIED_BY OR :P6_IDENTIFIED_BY = '-1') AND (RELATED_PROJECT = :P6_RELATED_PROJECT OR :P6_RELATED_PROJECT = '-1') AND (ASSIGNED_TO = :P6_ASSIGNED_TO OR :P6_ASSIGNED_TO = '-1') AND (STATUS = :P6_STATUS OR :P6_STATUS = '-1') AND (PRIORITY = :P6_PRIORITY OR :P6_PRIORITIY = '-1')
To use the preceding WHERE
clause, you must convert the Issues region into a PL/SQL Function Body Returning a SQL Query.
To turn the Issues region into a PL/SQL Function Body Returning a SQL Query:
Under Regions, click Issues.
Under Name, for Type, select SQL Query (PL/SQL function body returning SQL query).
For Region Source, replace the existing statements with the following:
DECLARE q VARCHAR2(32767); -- query w VARCHAR2(4000) ; -- where clause we VARCHAR2(1) := 'N'; -- identifies if where clause exists BEGIN q := 'SELECT "ISSUE_ID", '|| ' "ISSUE_SUMMARY", '|| ' "IDENTIFIED_BY", '|| ' "RELATED_PROJECT", '|| ' "ASSIGNED_TO", '|| ' "STATUS", '|| ' "PRIORITY", '|| ' "TARGET_RESOLUTION_DATE", '|| ' "ACTUAL_RESOLUTION_DATE" '|| ' FROM "#OWNER#"."HT_ISSUES" '; IF :P6_IDENTIFIED_BY != '-1' THEN w := ' IDENTIFIED_BY = :P6_IDENTIFIED_BY '; we := 'Y'; END IF; IF :P6_RELATED_PROJECT != '-1' THEN IF we = 'Y' THEN w := w || ' AND RELATED_PROJECT = :P6_RELATED_PROJECT '; ELSE w := ' RELATED_PROJECT = :P6_RELATED_PROJECT '; we := 'Y'; END IF; END IF; IF :P6_ASSIGNED_TO != '-1' THEN IF we = 'Y' THEN w := w || ' AND ASSIGNED_TO = :P6_ASSIGNED_TO '; ELSE w := ' ASSIGNED_TO = :P6_ASSIGNED_TO '; we := 'Y'; END IF; END IF; IF :P6_STATUS != '-1' THEN IF we = 'Y' THEN w := w || ' AND STATUS = :P6_STATUS '; ELSE w := ' STATUS = :P6_STATUS '; we := 'Y'; END IF; END IF; IF :P6_PRIORITY != '-1' THEN IF we = 'Y' THEN w := w || ' AND PRIORITY = :P6_PRIORITY '; ELSE w := ' PRIORITY = :P6_PRIORITY '; we := 'Y'; END IF; END IF; IF we = 'Y' THEN q := q || ' WHERE '|| w; END IF; RETURN q; END;
Note that this function first sets the variable q
to the original SELECT
statement. It then builds a WHERE
clause (w
) composed of just the variables set by the user. If any variables have been set, it appends the WHERE
clause to the original SELECT
and passes that new SELECT
to the database.
The report is now complete. Click the Run Page icon. The revised report appears and should resemble Figure 14-10.
To change the report parameters, make new selections under Issue Report Parameters and then click Go.
Currently, you can assign an issue by editing it. Next, you add a new page that enables users to assign multiple issues at once and modify the Related Project, Status, and Priority.
To add a new page to support assigning multiple issues:
Go to the Application home page.
Click Create Page.
Select Tabular Form and click Next.
For Table/View Owner:
Table/View Owner- Select the appropriate schema.
For this exercise, assume that the purpose of this form is to enable users to assign issues, or update existing records, and not create or delete issues.
Allowed Operations - Select Update Only.
Click Next.
For Displayed Columns:
Press CTRL and select the following columns:
ISSUE_SUMMARY
IDENTIFIED_BY
IDENTIFIED_DATE
RELATED_PROJECT
ASSIGNED_TO
STATUS
PRIORITY
Click Next.
For Primary Key Source, accept the default, Existing trigger, and click Next.
For Updatable Columns:
RELATED_PROJECT
ASSIGNED_TO
STATUS
PRIORITY
Click Next.
For Page and Region Attributes:
Page - Enter 8
Page Name - Enter Assign Issues
Region Title - Enter Assign Issues
Click Next.
For Button Labels:
For Cancel Button Label, accept the default.
For Submit Button Label, enter Apply Changes
Click Next.
For Branching, accept the defaults and click Next.
Once you have created the initial tabular form, you need to add lists of values to make it easier to select issues. Additionally, you need to restrict the query to display only unassigned issues.
To add lists of values:
From the Success page, click Edit Page.
The Page Definition for page 8, Assign Issues, appears.
Under Regions, click Assign Issues.
Under Source, for Region Source, replace the existing statements with the following:
SELECT "ISSUE_ID", "ISSUE_SUMMARY", "IDENTIFIED_BY", "IDENTIFIED_DATE", "RELATED_PROJECT", "ASSIGNED_TO", "STATUS", "PRIORITY" FROM "#OWNER#"."HT_ISSUES" WHERE assigned_to IS NULL
To edit report attributes:
Select the Report Attributes tab at the top of the page.
Edit the heading for ISSUE_SUMMARY.
For ISSUE_SUMMARY, enter the following in the Heading field:
Summary
To sort by ISSUE_ID:
For all columns except ISSUE_ID, select Sort.
For IDENTIFIED_DATE, for Sort Sequence, select 1.
Edit the following attributes for IDENTIFIED_BY:
Click the Edit icon to the left of IDENTIFIED_BY.
Under Tabular Form Element, for Display As, select Display as Text (based on LOV, does not save state).
Click the Next button (>) at the top of the page to go to IDENTIFIED_DATE.
Edit the following attributes for IDENTIFIED_DATE:
Click the Next button (>) at the top of the page to go to the RELATED_PROJECT column.
Edit the following attributes for RELATED_PROJECT:
Under Tabular Form Element, for Display As, select Select List (named LOV).
Under List of Values, for Named LOV, select PROJECTS.
Click the Next button (>) at the top of the page to go to the ASSIGNED_TO column.
Edit the following attributes for ASSIGNED_TO:
Click the Next button (>) at the top of the page to go to the STATUS column.
Edit the following attributes for STATUS:
Under List of Values, for Named LOV, select STATUS.
Click the Next button (>) at the top of the page to go to the PRIORITY column.
Edit the following attributes for PRIORITY:
From Named LOV, select PRIORITIES.
For Display Null, select Yes.
For Null Text, enter a hyphen (-).
Scroll down to Sorting. Under Ascending and Descending Image, select the light gray arrow.
No Unassigned Issues.
The wizard created an unnecessary Cancel button.
To delete the Cancel button:
On the Page Definition for page 8, click CANCEL in the Buttons section.
Click Delete.
The tabular form is now complete. To view the new form, click the Run Page icon. The Assign Issues form appears as shown in Figure 14-11.
To assign an issue, make a selection from the Assigned To list and then click Apply Changes. Notice that once an issue has been assigned, the issue no longer displays.
Lastly, you need to add four summary reports.
The Issue Summary report enable users to select a project and then see a summary of issues related to that project. This report includes the following summary information:
Date first issue identified
Date last issue closed
Total number of issues
Number of issues by status
Number of open issues by priority
Assignments by status
To create this report, you code the information in two SQL statements. The first statement gathers information having a singular result and the second statement gathers information having multiple results.
To add an Issue Summary by Project report:
Click Create Page.
Select Report and click Next.
Select SQL Report and click Next.
For Page Attributes:
Page - Enter 9
Page Name - Enter Issue Summary by Project
Click Next.
For SQL Query:
Enter the following SQL SELECT statement:
SELECT MIN(identified_date) first_identified, MAX(actual_resolution_date) last_closed, COUNT(issue_id) total_issues, SUM(DECODE(status,'Open',1,0)) open_issues, SUM(DECODE(status,'On-Hold',1,0)) onhold_issues, SUM(DECODE(status,'Closed',1,0)) closed_issues, SUM(DECODE(status, 'Open',decode(priority,null,1,0), 0)) open_no_prior, SUM(DECODE(status, 'Open',decode(priority,'High',1,0), 0)) open_high_prior, SUM(DECODE(status, 'Open',decode(priority,'Medium',1,0), 0)) open_medium_prior, SUM(DECODE(status, 'Open',decode(priority,'Low',1,0), 0)) open_low_prior FROM ht_issues WHERE related_project = :P9_PROJECT
Click Next.
For Report Attributes:
Report Template - Select default: vertical report, look 1 (include null columns).
For Region Name - Enter Issue Summary by Project
Now that you have the first query, you need to edit the headings and create the item to control the related project. First, create a region to display above the report to contain the Project parameter.
To create a new region to display above the report:
The Page Definition for page 9, Issue Summary by Project, appears.
Title - Enter Issue Summary Report Parameters
To create the Project item:
For Select List Control Type, accept the default, Select List, and click Next.
Item Name - Enter P9_PROJECT
Region - Select Issue Summary Report Parameters.
Click Next.
For List of Values:
Null Text - Enter:
- Select -
Null Text - Enter:
- 1
Click Next.
For Source, for Default, enter -1
Click Create Item.
To create a Go button to execute the query:
For Button Region, select Issue Summary Report Parameters and click Next.
For Button Position, select Create a button displayed among this region's items and click Next.
Button Name - Enter P9_GO
Next, you need to edit the headings and report setting for the report region. You also need to set the report regions to conditionally display when the user has selected a project.
To edit the headings and report settings:
Under Regions, click Report next to Issue Summary by Project.
For Headings Type, select Custom.
Under Column Attributes:
Change the Heading for FIRST_IDENTIFIED to:
First Issue Identified:
Change the Heading for LAST_CLOSED to:
Last Issue Closed:
Change the Heading for TOTAL_ISSUES to:
Total Issues:
Change the Heading for OPEN_ISSUES to:
Open Issues:
Change the Heading for ONHOLD_ISSUES to:
On-Hold Issues:
Change the Heading for CLOSED_ISSUES to:
Closed Issues:
Change the Heading for OPEN_NO_PRIOR to:
Open Issues with No Priority:
Change the Heading for OPEN_HIGH_PRIOR:
Open Issues of High Priority:
Change the Heading for OPEN_MEDIUM_PRIOR to:
Open Issues of Medium Priority:
Change the Heading for OPEN_LOW_PRIOR:
Open Issues of Low Priority:
For Show Null Values as, enter a hyphen (-).
For Pagination Scheme, select - No Pagination Selected -.
Select the Region Definition tab at the top of the page.
For Condition Type, select Value of Item in Expression 1 Is NOT Contained within Colon Delimited List in Expression 2.
In Expression 1, enter P9_PROJECT
For Expression 2, enter -1
To create a query to retrieve assignments by status.
Select Report and then click Next.
For Report Implementation, select SQL Report and click Next.
Title - Enter Assignments by Status
Column - Select 2.
For Source:
SQL Query or PL/SQL function returning a SQL Query - Enter the following:
SELECT p.person_name, i.status, COUNT(i.issue_id) issues FROM ht_issues i, ht_people p WHERE i.related_project = :P9_PROJECT AND i.assigned_to = p.person_id GROUP BY person_name, status
Rows Per Page - Enter 20
Break Columns - Select Column 1.
For Conditional Display:
Condition Type - Select Value of Item in Expression 1 Is NOT Contained within Colon Delimited List in Expression 2.
In Expression 1 enter:
P9_PROJECT
For Expression 2 enter -1
To edit headings and report settings:
Under Regions, click Report next to Assignments by Status.
For PERSON_NAME, change Heading to Assigned To
Scroll down to Layout and Pagination. From Pagination Scheme, select Row Ranges 1-15 16-30 in select list (with pagination).
Scroll down to Messages. In When No Data Found Message, enter:
No issues found.
To see your newly created report, click the Run Page icon. Note that initially no data displays since no project is selected. Select a project and click Go. Your report should resemble Figure 14-12.
Figure 14-12 Issue Summary by Project Report
The Resolved by Month Identified report is a line chart. This report first calculates the number of days it took to resolve each closed issue, averaged by the month the issue was identified, and finally displayed by the month.
To add a Resolved by Month Identified report:
Click Create Page.
Select Chart and click Next.
Select SVG Chart and click Next.
Select Line and click Next.
Page Number - Enter 10
Page Name and Region Name - Enter Resolved by Month Identified
For Query:
Series Name - Enter Resolved
SQL - Enter the following:
SELECT NULL l, TO_CHAR(identified_date,'Mon YYYY') month, AVG(actual_resolution_date-identified_date) days FROM ht_issues WHERE status = 'Closed' GROUP BY TO_CHAR(identified_date,'Mon YYYY')
Note that this query has no link (that is, the l column). It extracts the month from the identified date so that the data can be grouped by month. Lastly, it calculates the average number of days it took for the issues to be closed that were identified in that month.
For When No Data Found Message, enter:
No Closed Issues found.
Click Next.
Next, add a correct axis label and turn off the Chart Title and legend.
To edit the chart:
From the Success page, select Edit Page.
The Page Definition for page 10, Resolved by Month Identified, appears.
Under Regions, click SVG Chart, next to Resolved by Month Identified.
Under Chart Settings:
Chart Height - Enter 300
Deselect Show Legend.
Scroll to Axes Setting:
For X Axis Title, enter Date Identified
For Y Axis Title, enter Days to Resolve
To view your newly created line chart, click the Run Page icon. Your line chart should resemble Figure 14-13.
Figure 14-13 Resolved by Month Identified Line Chart
The Target Resolution Dates report is a calendar that displays issues that have not yet closed along with the assigned person on the day that corresponds to the issue target resolution date.
To create a calendar of target resolution dates:
Click Create Page.
Select Calendar and click Next.
Select SQL Calendar and click Next.
Page Number - Enter 11
Page Name and Region Name - Enter Target Resolution Dates
Click Next.
In Enter SQL Query, enter the following:
SELECT I.TARGET_RESOLUTION_DATE, I.ISSUE_SUMMARY || ' ('||nvl(P.PERSON_NAME,'Unassigned') ||') ' disp, I.ISSUE_ID FROM HT_ISSUES I, HT_PEOPLE P WHERE I.ASSIGNED_TO = P.PERSON_ID (+) AND (I.RELATED_PROJECT = :P11_PROJECT OR :P11_PROJECT = '-1') AND I.STATUS != 'Closed'
Click Next.
Note that:
The target_resolution_date
is the date on which the issue displays
The issue_summary
is concatenated with the person assigned
The issue_id
does not display, but is used to create a link to enable the user to view and edit the issue
For Date/Display Columns:
Date Column - Select TARGET_RESOLUTION_DATE.
For Display Column - Select DISP.
Click Next.
To enable the user to look up one project or all projects, you need to add an item.
To add an item to support project look up:
The Page Definition for page 11, Target Resolution Dates, appears.
For Item Type, select Select List and click Next.
For Select List Control Type, select Select List and click Next.
Item Name - Enter P11_PROJECT
For List of Values:
Null Text - Enter:
- All Projects -
-1
Click Next.
-1
Click Create Item.
For Button Region, select Target Resolution Dates and click Next.
Button Name - Enter P11_GO
Lastly, you need to modify the Calendar Attributes to add link support for viewing and editing the displayed issues. To accomplish this, you need to call page 7, View/Edit Issues, clear any data from the page and pass in the current issue ID along with the fact that page 11 was the calling page. Then, you need to add a note that displays when the query excludes Closed issues.
To modify the Calendar Attributes:
Under Regions, click Calendar to the right of Target Resolution Dates.
Scroll down to Column Link, enter the following:
Page - Enter 7
Set these items - Enter:
P7_ISSUE_ID,P7_PREV_PAGE
For With these values - Enter:
#ISSUE_ID#,11
Scroll down to Header and Footer.
In Region Footer, enter the following:
This excludes Closed issues.
To see your newly created calendar, click the Run Page icon. Your report should resemble Figure 14-14. Note that you can click Weekly or Daily to see the corresponding calendar views.
Note that you can also click the text displayed for an issue to display the Edit Issue page. To return to the calendar, click Cancel.
Figure 14-14 Target Resolution Dates Report
The Average Days to Resolve report is a bar chart that calculates the number of days it takes to resolve each closed issue and then averages that number by assigned person.
To add the Average Days to Resolve report:
Click Create Page.
Select HTML Chart and click Next.
Select Bar (HTML) and click Next.
Page - Enter 12
Page Name and Region Name - Enter Average Days to Resolve
For Chart Definition:
Chart SQL - Replace the existing statements with the following:
SELECT NULL l, NVL(p.person_name,'None Assigned') person, AVG(i.actual_resolution_date-i.identified_date) days FROM ht_issues i, ht_people p WHERE i.assigned_to = p.person_id (+) AND i.status = 'Closed' GROUP BY p.person_name
In the above SELECT statement:
The first item selected is the link. This report does not link to any other page, and so NULL
was selected.
The second item is the person's name, or None Assigned
if assigned_to
is NULL
The third item selected is the average number of days it took for that person to resolve all their issues so the issues have a status of closed.
For Include in summary, select only Number of data points. Deselect all other options.
To view your newly created bar chart, click Run Page. Your report should resemble Figure 14-15.
Figure 14-15 Average Days to Resolve Report
Now that you have completed all the detail pages, you next need to add content to the home page and tie all the pages together. In this section, you modify the home page to display the following information:
A menu of all available reports
Navigation to the maintenance pages
A button to Add a New Issue
Overdue Issues
Recently Opened Issues
Open Issues by Project as a chart
Unassigned Issues
Topics in this section include:
First, you add a menu implemented as a list.
To add a menu:
Click the Shared Components icon.
Under Navigation, click Lists.
Click Create.
For Name, enter Main Menu
For List Template, select Vertical Sidebar List.
Click Create.
Now that the list has been created, you add list items to it. You need to add one list item for each report page.
To add a list item for Assign Issues:
Click the Create List Entry button on the far right of the page.
For List Entry Label, enter Assign Issues
Under Target, specify the following
Page - Select 8.
Select reset pagination for this page.
Click Create.
The List Entries page appears.
Now you need to create four more list items, one for each of the reports in your application.
To add four more list items:
On the List Entries page, click Create List Entry.
To define a list item for Issues:
For Sequence, enter 20
For List Entry Label, enter Issues
Under Target, specify the following:
Page - Select 6
Clear Cache - Enter 6.
This clears any selections for page 6 from the session state.
Click Create and Create Another.
To define a list item for Issue Summary:
For Sequence, enter 30
For List Entry Label, enter Issue Summary by Project
Page - Select 9.
Clear Cache - Enter 9.
To define a list item for Resolved by Month Identified:
For Sequence, enter 40
For List Entry Label, enter Resolved by Month Identified (chart)
Under Target, select 10 for Page.
To define a list item for Target Resolution Dates:
For Sequence, enter 50
For List Entry Label, enter Target Resolution Dates (calendar)
Page - Select 11.
To define a list item for Average Days to Resolve:
For Sequence, enter 60
For List Entry Label, enter Average Days to Resolve (chart)
Under Target, select 12 for Page.
Click Create.
Now that the list is created, you need to include it on the home page. To display the list in the left margin, you need to change the page template to one that supports the appropriate region position.
To change the page template on the home page:
The Page Definition for page 12, Average Days to Resolve, appears.
In the Page field, enter 1
and click Go.
Under Page, click the Edit page attributes icon.
The Page attributes page appears.
Under Display Attributes, for Page Template, select No Tabs with Sidebar.
Next, create a region to contain your menu.
Title - Enter Menu
Region Template - Select No Template.
Display Point - Select Page Template Region Position 2 (or select the quick link [Pos. 2]).
Click Next.
For Source, select Main Menu.
Click Create List Region.
Next, you need to add maintenance navigation as a list. This list will display just below the reports in the left margin.
Click Create.
For Name, enter Maintenance
Click Create.
Next, create three list items. The first list item acts as a separator between the two navigation regions. The other two enable users to view people and projects.
To add list items:
Click Create List Entry.
To define the first list item:
For List Entry Label, enter:
Under Target, select 1 for Page.
To define a list item for Projects:
Projects
Under Target:
For Page, select 2.
Check reset pagination for this page.
To define a list item for People:
People
Under Target:
For Page, select 4.
Click Create.
To create a region to display the new list.
Title - Enter Maintenance
Click Next.
For Source, select Maintenance.
Next, you create a button to navigate the user to page 7, Create/Edit Issue.
To create a region to contain the button:
Select HTML for the region container and click Next.
Display Point - Select Page Template Region Position 1 (or select the quick link [Pos. 1]).
Click Next.
To add a button:
For Button Region, select Buttons and click Next.
For Button Position, accept the default, Create a button in a region position, and then click Next.
Button Name - Enter ADD
Label - Enter:
Add a New Issue
Action - Select Redirect to URL without submitting page.
Click Next.
For Button Template, select Button and click Next.
For Position, select Top of Region, accept the remaining defaults, and click Next.
On the Branching page, you need to call the correct page, clear the cache, and specify that the Create and Cancel buttons return the user to the home page.
For Branching, specify the following:
Page - Select 7.
P7_PREV_PAGE
With these values - Enter 1
Next, add some content to the home page. In this exercise, you add a report to display overdue issues. The query for this report retrieves all unclosed issues with a past target resolution date.
To add a report to display overdue issues:
For Display Attributes, enter Overdue Issues
in the Title field and click Next.
For Source, enter the following in Enter SQL Query:
SELECT i.issue_id, i.priority, i.issue_summary, p.person_name assignee, i.target_resolution_date, r.project_name FROM ht_issues i, ht_people p, ht_projects r WHERE i.assigned_to = p.person_id (+) AND i.related_project = r.project_id AND i.target_resolution_date < sysdate AND i.status != 'Closed'
The outer join is necessary because the assignment is optional.
Now that the region has been created, you need to edit the headings and turn the summary into a link to display the issue details.
To edit the column headings:
Under Regions, click Report next to Overdue Issues.
For ISSUE_ID, remove the Heading.
For ISSUE_SUMMARY, enter the following for Heading:
Summary
For ASSIGNEE, change the Heading to:
Assigned To
For Heading, enter:
For ISSUE_ID, deselect Show.
This enables the query to pass in the link, but not display it.
To sort by issue ID, select Sort for all columns except ISSUE_ID.
For TARGET_RESOLUTION_DATE, select 1 for Sort Sequence.
For ISSUE_SUMMARY, select 2 for Sort Sequence.
To edit column attributes for ISSUE_SUMMARY:
Click the Edit icon to the left of ISSUE_SUMMARY.
Scroll down to Column Link:
For Link Text, click the quick link of [Icon 3].
For Page, select 7.
For Clear Cache, select 7.
For Item 1, enter the Name:
P7_ISSUE_ID
For Item 1, enter the Value:
#ISSUE_ID#
For Item 2, enter the Name:
P7_PREV_PAGE
For Item 2, enter the Value:
1
To select layout and pagination attributes:
Under Layout and Pagination:
For Pagination Scheme, select Search Engine 1,2,3,4 (set based pagination).
For Number of Rows, enter 5
No Overdue Issues.
The next report you add displays unassigned, open issues. This report is very similar to Overdue Issues. Rather than creating it manually, you can copy the Overdue Issues report and modify it.
To create a new report by copying an existing report:
Under Regions, click the Copy icon.
In the Name column, click Overdue Issues.
For To Page, accept the default 1, accept the remaining defaults, and click Next.
For Region Name, enter Unassigned Issues
Click Copy Region.
To modify the query and edit the report region:
Under the Regions section, click Unassigned Issues.
SELECT i.issue_id, i.priority, i.issue_summary, i.target_resolution_date, r.project_name, p.person_name identifiee FROM ht_issues i, ht_people p, ht_projects r WHERE i.assigned_to IS NULL AND i.status != 'Closed' AND i.related_project = r.project_id AND i.identified_by = p.person_id
Note that previously defined columns have retained their modified attributes.
For IDENTIFIEE, enter the following Heading:
Identified By
Lastly, you add a report of recently opened issues. The underlying query displays the five most recently opened issues.
To create a report of recently opened issues by copying an existing report:
Under Name, select Unassigned Issues.
For Region Name, enter Recently Opened Issues
Click Copy Region.
Under Regions, click Report next to Recently Opened Issues.
For all columns:
Disable sorting by deselecting Sort.
Set Sequence to -.
SELECT issue_id, priority, issue_summary, assignee, target_resolution_date, project_name, identifiee FROM ( SELECT i.issue_id, i.priority, i.issue_summary, p.person_name assignee, i.target_resolution_date, r.project_name, p2.person_name identifiee FROM ht_issues i, ht_people p, ht_people p2, ht_projects r WHERE i.assigned_to = p.person_id (+) AND i.related_project = r.project_id AND i.identified_by = p2.person_id AND i.created_date > (sysdate - 7) ORDER BY i.created_date desc ) WHERE rownum < 6
For ASSIGNEE, click the up arrow to the right of the Sort Sequence column until ASSIGNEE appears after ISSUE_SUMMARY.
For ASSIGNEE, change Heading to:
Assigned To
Scroll down to the Layout and Pagination section. From Pagination Scheme, select - No Pagination Selected -.
No Recently Opened Issues.
Next, add a pie chart displaying Open Issues by Project.
To add a pie chart:
Select Pie and click Next.
For Display Attributes, enter Open Issues by Project
in Title and then click Next.
For Source, enter the following in SQL:
SELECT NULL LINK, NVL(r.project_name,'No Project') label, COUNT(r.project_name) value FROM ht_issues i, ht_projects r WHERE i.status = 'Open' AND i.related_project = r.project_id GROUP BY NULL, r.project_name ORDER BY r.project_name
Note that this query does not include a link, the label is the Project Name
, and the value calculated and used for the pie chart is the total number of open issues by project.
To edit the chart.
Under Regions, click SVG Chart next to Open Issues by Project.
For Chart Width, enter 500
For Chart Height, enter 200
For Chart Title, remove the title.
Under Chart Query, enter the following in When No Data Found Message:
No Open Issues.
Under Font Settings, for Legend, select 14 for the Font Size.
To view the revised page, click the Run Page icon. Your home page should resemble Figure 14-16.
In the previous exercise, you created menus on the home page to enable users to navigate to various pages within your application. Next, you need to provide users with a way to navigate to the home page. You can accomplish this by utilizing breadcrumbs. You can add breadcrumbs when you create a new page, or manually after you create your pages.
In the next exercise, you add breadcrumb entries and then include that breadcrumb within a region on page 0. Adding components to page 0 makes them display on all pages with an application.
To navigate to the Breadcrumbs page:
Click Shared Components.
Under Navigation, click Breadcrumbs.
Click the Breadcrumb icon.
The Breadcrumb Entries page appears.
Next, you edit the existing breadcrumb entry and add breadcrumb entries for other pages.
To edit the breadcrumb entry for page 1:
Under Breadcrumb Entries, click Page 1.
Under Breadcrumb, enter 1
in Page.
Under Entry, enter Home
for Short Name.
Under Target, enter 1
in Page.
To add a breadcrumb entry for page 2:
Click Create Breadcrumb Entry.
Under Breadcrumb, enter 2
in Page.
Under Entry:
Parent Entry - Select Home.
Short Name - Enter Projects
Under Target, enter 2
in Page.
Click Create.
To create a breadcrumb entry for page 3:
Under Breadcrumb, enter 3
in Page.
Under Entry:
Parent Entry - Select Projects.
For Short Name - Enter Create/Edit Projects
Under Target, enter 3
in Page.
Click Create.
To create a breadcrumb entry for page 4:
Under Breadcrumb, enter 4
in Page.
Under Entry:
For Parent Entry - Select Home.
For Short Name - Enter People
Under Target, enter 4 in Page.
Click Create.
Note that the People breadcrumb entry is a sibling to Projects.
To create a breadcrumb entry for page 5:
Under Breadcrumb, enter 5
in Page.
Under Entry:
For Parent Entry - Select People.
For Short Name - Enter Create/Edit Person Information
Under Target, enter 5 in Page.
Click Create.
To create a breadcrumb entry for page 6:
Under Breadcrumb, enter 6
in Page.
Under Entry:
For Short Name - Enter Issues
Under Target, enter 6 in Page.
Click Create.
To create a breadcrumb entry for page 7:
Under Breadcrumb, enter 7
in Page.
Under Entry:
For Short Name - Enter Create/Edit Issue
Under Target, enter 7 in Page.
Click Create.
To create a breadcrumb entry for page 8:
Under Breadcrumb, enter 8
in Page.
Under Entry:
For Short Name - Enter Assign Issues
Under Target, enter 8
in Page.
Click Create.
To create a breadcrumb entry for page 9:
Under Breadcrumb, enter 9
in Page.
For Entry:
For Short Name - Enter Issue Summary by Project
Under Target, enter 9
in Page.
Click Create.
To create a breadcrumb entry for page 10:
Under Breadcrumb, enter 10
in Page.
Under Menu Option:
For Parent Entry- Select Home.
For Short Name - Enter Resolved by Month Identified
Under Target, enter 10
in Page.
Click Create.
Now that the breadcrumb exists, you need to create page 0 and then create a region to contain your Breadcrumb menu. Adding components to page 0 makes them display on all pages with an application.
To create a page 0:
Click Create Page.
Select Blank Page and click Next.
For Page Attributes, enter 0
for Page Number and click Next.
For Page Name, enter Breadcrumbs for Name and click Next.
On Tabs, accept the default, No, and then click Next.
To create a region to contain your breadcrumb:
The Page Definition for page 0 appears.
For Identify the type of region to add to this page, select Breadcrumb and click Next.
For Breadcrumb Container Region:
Region Title - Enter Breadcrumbs.
Display Point - Select Page Template Region Position 1.
This selection displays the breadcrumb above all other content on the page.
Click Next.
For Breadcrumb, accept the defaults and click Next.
For Breadcrumb Entry, accept the defaults and click Next.
Click Finish.
Return to the home page by clicking Edit Page. When the Page Definition for page 0 appears, click the Next Page button (>). The Page Definition for page 1 appears.
To see your completed home page, click the Run Page icon. Your home page should resemble Figure 14-17.
Figure 14-17 Revised Home Page with Breadcrumb Menu
Notice the Breadcrumb in the top bar. Click one of the items on the Maintenance menu on the left side of the page. Notice how the breadcrumb changes.
At this stage your application is fully functional, but is missing the security and email notification. Those topics are discussed in the next section.
Once your application is fully functional you can focus on adding advanced features outlined during the planning and project analysis phase.
The planning and project analysis phase produced two email requirements:
Notify people when an issue is assigned to them
Notify the project lead when any issue becomes overdue
To send mail from within an Oracle Application Express application, you create a PL/SQL process that calls the supplied APEX_MAIL
package.
Email is not sent immediately, but is stored in a temporary queue until a DBMS_JOB
pushes the queue. The DBMS_JOB
utilizes two preferences, SMTP Host Address and SMTP Host Port, to send mail in the queue. By default, these preferences are set to localhost
and 25
. If Oracle Application Express is not configured for SMTP services, you need to change your Email Environment Settings.
See Also:
"How to Send Email from an Application" in Oracle Database Application Express User's Guide to learn about configuring Email Environment settings.The following is a description of the SEND
procedure of the APEX_MAIL
package.
PROCEDURE SEND Argument Name Type In/Out Default? ------------------------------ ----------------------- ------ -------- P_TO VARCHAR2 IN P_FROM VARCHAR2 IN P_BODY VARCHAR2 IN P_BODY_HTML VARCHAR2 IN DEFAULT P_SUBJ VARCHAR2 IN DEFAULT P_CC VARCHAR2 IN DEFAULT P_BCC VARCHAR2 IN DEFAULT
First, you add a notification to a person when the person has a new assignment. An assignment can be made or changed from two different pages: Create/Edit Issue and Assign Issues.
On the Create/Edit Issue page, you can store the initial values and then check them against any changes to see if an assignment has been made or changed. The Assign Issues is a tabular form, so there is no way to check the old values against the new values. For that reason, the best way to implement the notification is with a before insert and update trigger on HT_ISSUES
. You can create this trigger programmatically using SQL Workshop.
To create a before insert and update trigger on HT_ISSUES
On the Workspace home page, click SQL Workshop and then Object Browser.
Click Create.
For Select the type of database object you want to create, click Trigger.
For Table Name, select HT_ISSUES and click Next.
For Define:
For Trigger Name, enter BIU_HT_ISSUES_NOTIFY_ASSIGNEE
For Firing Point, select AFTER.
For Options, select insert, update.
For Trigger Body, enter the following:
IF (INSERTING AND :new.assigned_to IS NOT NULL) OR (UPDATING AND (:old.assigned_to IS NULL OR :new.assigned_to != :old.assigned_to) AND :new.assigned_to IS NOT NULL) THEN FOR c1 IN (SELECT person_name, person_email FROM ht_people WHERE person_id = :new.assigned_to) LOOP IF c1.person_email IS NOT NULL THEN FOR c2 IN (SELECT project_name FROM ht_projects WHERE project_id = :new.related_project) LOOP -- APEX_MAIL.SEND( -- p_to => c1.person_email, -- p_from => c1.person_email, -- p_body => -- 'You have been assigned a new issue. -- 'The details are below. ' ||chr(10)|| -- chr(10)|| -- ' Project: '|| c2.project_name ||chr(10)|| -- ' Summary: '||:new.issue_summary ||chr(10)|| -- ' Status: '||:new.status ||chr(10)|| -- 'Priority: '||nvl(:new.priority,'-'), -- p_subj => 'New Issue Assignment'); END LOOP; END IF; END LOOP; END IF;
To make this work within your environment, uncomment the APEX_MAIL.SEND and replace the p_to
and p_from
with your own valid email address.
Click Next.
To review the code, expand the SQL arrow.
Click Finish.
The second email notification notifies the project lead whenever an issue becomes overdue. An issue becomes overdue when the target resolution date has passed, but the issue is not yet closed. There is no human interaction to determine if an issue is overdue, so you cannot check for it on a page or in a trigger.
The best way to check for overdue issues is to write a package that queries the HT_ISSUES
table. If it finds any overdue issues, the package initiates an email to the Project Lead. This procedure checks for issues by project so that the project lead can receive just one email with all overdue issues rather than an email for each issue. The package will be called once a day by a dbms_job
You can use the Create Object function as follows:
Create the package and package body from within the SQL Workshop
Use SQL Command Processor to run the create commands
To create the package:
On the Workspace home page, click SQL Workshop and then SQL Commands.
SQL Commands appears.
Enter the following in the field provided:
CREATE OR REPLACE package ht_check_overdue_issues AS PROCEDURE email_overdue; END; /
Click Run.
To create the package body:
CREATE OR REPLACE PACKAGE BODY ht_check_overdue_issues AS PROCEDURE email_overdue IS l_msg_body varchar2(32000) := null; l_count number := 0; BEGIN FOR c1 IN (SELECT pr.project_id, pr.project_name, pe.person_name, pe.person_email FROM ht_projects pr, ht_people pe WHERE pr.project_id = pe.assigned_project AND pe.person_role = 'Lead') LOOP FOR c2 IN (SELECT i.target_resolution_date, i.issue_summary, p.person_name, i.status, i.priority FROM ht_issues i, ht_people p WHERE i.assigned_to = p.person_id (+) AND i.related_project = c1.project_id AND i.target_resolution_date < SYSDATE AND i.status != 'Closed' ORDER BY i.target_resolution_date, i.issue_summary) LOOP IF l_count = 0 THEN l_msg_body := 'As of today, the following issues '|| 'are overdue:'||chr(10)|| chr(10)|| ' Project: '|| c1.project_name ||chr(10)|| chr(10)|| ' Target: '||c2.target_resolution_date ||chr(10)|| ' Summary: '||c2.issue_summary ||chr(10)|| ' Status: '||c2.status ||chr(10)|| ' Priority: '||c2.priority ||chr(10)|| 'Assigned to: '||c2.person_name; ELSE l_msg_body := l_msg_body ||chr(10)|| chr(10)|| ' Target: '||c2.target_resolution_date ||chr(10)|| ' Summary: '||c2.issue_summary ||chr(10)|| ' Status: '||c2.status ||chr(10)|| ' Priority: '||c2.priority ||chr(10)|| 'Assigned to: '||c2.person_name; END IF; l_count := l_count + 1; END LOOP; IF l_msg_body IS NOT NULL THEN -- APEX_MAIL.SEND( -- p_to => c1.person_email, -- p_from => c1.person_email, -- p_body => l_msg_body, -- p_subj => 'Overdue Issues for Project '|| c1.project_name); END IF; l_count := 0; END LOOP; END email_overdue; END ht_check_overdue_issues; /
and p_from
Click Run.
Next, you want to update the demonstration data to include your employees' valid email addresses.
To update demonstration data to include valid email addresses:
From the Object list on the left side of the page, select Tables.
Select the HT_PEOPLE table.
Select the Data tab.
For each person, edit the email address:
Click the Edit icon.
Change Person Email to a valid email address.
Click Apply Changes.
Repeat step 5 for all people within the HT_PEOPLE table.
Return to the Workspace home page by clicking the Home breadcrumb link.
Next, you want to create a DBMS_JOB
that executes your newly created package at a time interval you specify.
To create the DBMS_JOB
The following is an example of a DBMS_JOB
that executes your newly created package. To make this a valid DBMS_JOB
, however, you need to set the interval appropriately and execute it using SQL Commands within the SQL Workshop.
DECLARE
jobno number;
BEGIN
DBMS_JOB.SUBMIT(
job => jobno,
what => 'BEGIN
ht_check_overdue_issues.email_overdue;
END;',
next_date => SYSDATE,
interval => desired_interval
COMMIT;
END;
For this DBMS_JOB
, replace desired_interval
with the appropriate interval. For example, to have this job execute once each day, you would replace desired_interval
with the following:
'TRUNC(SYSDATE)+(25/24)'
See Also:
Send email from Application Express applications How To on OTN at:http://www.oracle.com/technology/products/database/application_express/howtos/index.html
The planning and project analysis phase produced two security requirements:
Only the CEO and Managers can define and maintain projects and people
Once assigned, only the person assigned or a project lead can change data about the issue
Within Oracle Application Express, you can define authorization schemes. Authorization controls user access to specific controls or components based on user privileges. Once defined, you can associate an authorization scheme with any page, region, or item to restrict access. Each authorization schema is run only when needed and is defined to validate either once for each page view or once for each session.
The first requirement states that only the CEO and Managers may define and maintain projects and people. To address this requirement, you:
Create an authorization scheme to check the current user's role
Associate the authorization scheme with the items on the Projects and People report that navigate to the Create/Edit pages
Associate the authorization scheme with the Create/Edit pages themselves so that a user cannot bypass the security by manually editing the URL to the target page
To reference the current user, use the session variable :APP_USER
. This session variable is compared with the person's email address (which is the same as their workspace or workspace name). Whenever coding this type of security, you should always code in a user that can pass all security. You may find this user very useful for development and testing. If you do not take this approach, you may not be able to access the restricted pages unless you define yourself as the CEO or Manager.
Create the Authorization Scheme
To create the authorization scheme:
On the Workspace home page, click Application Builder.
Select the Issue Tracker application.
Under Security, click Authorization Schemes.
Click Create.
For Create Authorization Scheme, accept the default, From Scratch, and click Next.
Under Authorization Scheme, enter the following in Name:
USER_CEO_OR_MANAGER
Under Authorization Scheme:
Scheme Type - Select Exists SQL Query.
Expression 1 - Enter:
SELECT '1' FROM ht_people WHERE (upper(person_email) = UPPER(:APP_USER) AND person_role IN ('CEO','Manager')) OR (UPPER(:APP_USER) = 'HOWTO')
Identify error message displayed when scheme violated - Enter:
You are not authorized to access this function.
Scroll down to Evaluation Point. For Validate authorization scheme, select Once per session.
This selection is sufficient in this instance as the assigned role typically does not change within a given session.
Click Create.
Next, you need to associate the authorization scheme with the appropriate objects.
Associate Objects on the Projects Report
To associate the authorization scheme with the Projects report:
Click the Edit Page icon in the upper right corner. The Edit Page icon resembles a small green piece of paper and pencil.
In Page, enter 2
and then click Go.
The Page Definition for page 2, Projects, appears.
Under Regions, click Report next to Projects.
Click the Edit icon to the left of PROJECT_ID
Under Authorization, select the Authorization Scheme USER_CEO_OR_MANAGER.
Click Cancel.
To associate the authorization scheme with the Create button on the Projects report:
Under Buttons on the Page Definition for page 2, click the Create link (not the icon).
The Edit Page Buttons page appears.
Associate Objects with the Create/Edit Report
To associate the authorization scheme with the Create/Edit Project page:
Go to page 3 by clicking the Next Page (>) button.
The Page Definition for page 3, Create/Edit Project, appears.
Under Security, select the Authorization Scheme USER_CEO_OR_MANAGER.
Associate Objects with the People Report
To associate the authorization scheme with the People report.
Go to page 4 by clicking the Next Page (>) button.
The Page Definition for page 4, People, appears.
Under Regions, click Report next to People.
Click the Edit icon to the left of PERSON_ID.
Click Cancel.
To associate the authorization scheme with the Create button on the People report:
Go to page 5 by clicking the Next Page (>) button.
The Page Definition for page 5 appears.
Under Buttons, click the Create link (not the icon).
To associate the authorization scheme with the Create/Edit Person Information page:
You can test this by creating a user with the user name of HOWTO. The HOWTO user should be able to see the edit link. Then, create another user, HOWTO2. This user should not be able to see the link.
See Also:
"Create Users"The second requirement states that once an issue has been assigned, only the person assigned (or a project lead) can change data about the issue. This requirement is a little trickier since it changes for every issue.
Currently, there are two pages that enable users to modify an issue: the Create/Edit Issue page and the Assign Issues page. On the Assign Issues page, the only issues that are displayed are those that are unassigned. As the issues are unassigned, security is not necessary.
There are many places that a user can navigate to edit an issue:
Three regions on the home page display issues or have edit links
The Issues report has links to edit each issue
The Target Resolution Dates report enables users to select an issue to edit.
Although other users are not allowed to change the data, you do want to enable users to view all the detailed data about an issue so that they can view the progress and resolution. Given this requirement, the best approach is to create an authorization scheme to be evaluated once for each page view.
The authorization scheme will be associated with both the Apply Changes and Delete buttons on the Create/Edit Issue page. This way, unauthorized users can view all the details, but if they do change something, they have no way of saving that change.
For added security, you can also associate the authorization scheme with the process that performs the insert, update and delete on HT_ISSUES
. This protects your application against someone changing the URL to call the Apply Changes process. To let users know why they are not able to make changes, you can add an HTML region that displays an explanation when the authorization fails. The SQL for this scheme must be specific to the Create/Edit Issues page because it needs to reference P7_ISSUE_ID. It also needs to retrieve data from the database because at the time it is evaluated, the necessary data will not be available in the session state. The only item that will be available will be P7_ISSUE_ID because it will be passed by the link.
Click Create.
For Creation Method, accept the default From Scratch and then click Next.
P7_ASSIGNED_OR_PROJECT_LEAD
For Scheme Type, select PL/SQL Function Returning Boolean.
For Expression 1, enter:
DECLARE l_related_project integer; l_assigned_to integer; l_person_id integer; l_person_role varchar2(7); l_assigned_project integer; BEGIN -- User is HOWTO or new Issue IF :APP_USER = 'HOWTO' or :P7_ISSUE_ID IS NULL THEN RETURN TRUE; END IF; FOR c1 IN (SELECT related_project, assigned_to FROM ht_issues WHERE issue_id = :P7_ISSUE_ID) LOOP l_related_project := c1.related_project; l_assigned_to := c1.assigned_to; END LOOP; -- Issue not yet assigned IF l_assigned_to IS NULL THEN RETURN TRUE; END IF; FOR c2 IN (SELECT person_id, person_role, assigned_project FROM ht_people WHERE upper(person_email) = upper(:APP_USER)) LOOP l_person_id := c2.person_id; l_person_role := c2.person_role; l_assigned_project := c2.assigned_project; END LOOP; -- User is lead of related project IF l_person_role = 'Lead' and l_assigned_project = l_related_project THEN RETURN TRUE; -- User is assigned to issue ELSIF l_assigned_to = l_person_id THEN RETURN TRUE; ELSE RETURN FALSE; END IF; END;
For Identify error message displayed when scheme violated, enter:
This issue is not assigned to you, nor are you the Project Lead. Therefore you are not authorized to modify the data.
Under Evaluation Point, for Validate authorization scheme, select Once per page view.
This selection is necessary since each issue may have a different result.
Click Create.
Now you need to associate the authorization scheme with the appropriate objects on the Create/Edit Issue page.
Associate Objects with the Create Edit Issues Report
To associate the authorization scheme with buttons and processes:
Select page 7 - Create/Edit Issues.
Under Buttons, click Delete.
Under Authorization, select the Authorization Scheme P7_ASSIGNED_OR_PROJECT_LEAD.
Under Buttons, click Apply Changes.
Under Buttons, click Create.
Under Buttons, click Create and Create Another.
Under Page Processing, Processes, select Process Row of HT_ISSUES.
Lastly, create a new region to display an explanation when the authorization fails
Under Regions, click the Create icon.
On Region, accept the default HTML and click Next.
For Title, enter Not Authorized
For Display Point, select Page Template Body (2. items below region content).
Click Next.
For Source, enter the following in Enter HTML Text Region Source and then click Next:
You are not authorized to modify the data for this issue because<br>you are not the Project Lead nor is the issue assigned to you.
For Authorization Scheme, select {Not P7_ASSIGNED_OR_PROJECT_LEAD}. This selection makes the region only display when the Authorization Scheme fails.
Figure 14-18 displays the Create/Edit Issue page being run by a person for whom the Authorization fails. Notice a new region displays at the top of the page and that the only button being displayed is Cancel.
Figure 14-18 New Region Displaying Authorization Failure
A more elegant solution to this security requirement would be to create a different page for viewing the details of an issue. You would need to have a procedure that would take in the issue_id and current user and pass back a flag for view only or edit. Then you could dynamically build the link for all the reports to call either the View page or the Edit page based upon a call to that procedure. You would still want to protect against someone accessing the edit page without using a link so you would also check permission before firing the insert, update and delete process.
Now that your application is complete, the next step is to deploy it. Typically, developers create applications on one server and deploy it on another. Although this approach is not required, it enables you to resolve bugs without impacting the production instance.
To deploy an application on another server, you need to install and configure another Oracle Application Express instance.Topics in this section include:
The definition for your application lives within the Oracle database. The application definition includes everything that makes up the application, including the templates, but it does not include database object definitions or the underlying data. To move an application to another Oracle Application Express instance, you must export the application definition from your development server and import it into your production server.
To export the application definition from your development server:
On the Workspace home page, click the arrow on the Application Builder icon and select the application you just created.
Click the Export/Import icon.
For Export/Import, click Export and then Next.
For Application, make sure the application created in this exercise is selected.
Click Export Application.
When prompted, click to Save the file.
Specify a location on your local hard drive and then click Save.
On your production instance, you need to create the objects necessary to support the application. Log in to the production instance and follow the directions in "About Building Database Objects".
Although the supporting objects do not need to exist for you to import the application definition, be aware you cannot test the code until they exist.Log in to the production instance of the Workspace home page:
On the Application home page, click Export/Import.
On the Export/Import page, click Import and then click Next.
For Import File:
Import file - Click the Browse button and then locate your exported file.
File Type - Select Application, Page, or Component Export.
File Character Set - Accept the default and click Next.
Once the success message appears, the next step is to install the file.
Click Install.
On Application Install:
Parse As Schema - Select the schema on your production server that contains your application objects.
Build Status, - Select Run and Build Application.
This option enables other users to run the application and enables you to log in and change the code if necessary. Alternatively, you can select Run Application Only. Be aware that if you select this option you will not be able to access the source code for the application.
Install As Application - You can select:
Reuse Application ID from Export File - Only select this option if the application ID is not being used on the production instance.
Auto Assign New Application ID - Select this option to assign a new application ID.
Change Application ID - Select this option to change the existing application ID. If you select this option, you will be prompted to enter a new application ID.
When you install an application having the same ID as an existing application in the current workspace, the existing application is deleted and then the new application is installed. If you attempt to install an application having the same ID as an existing application in a different workspace, an error message appears.
If all statements are successful the install commits and becomes permanent. If any errors are encountered, the install is rolled back, resulting in no permanent changes.
Click Install Application.
If the install is successful, the Post-App Install Utility Options page appears. From here, you can select one of the following:
Select Run Application to see the application running
Select Application Attributes to view the application definition within Application Builder
The next step in deploying your application is to load the data. At a minimum, you would need to populate the project
and people
tables.
Note there are various mechanisms you could use to accomplish this task, including:
Use the application itself to create data.
Use the Data Loader to load data copied from a spreadsheet.
Use SQL Scripts and run scripts to create data.
If you have data existing already within an Oracle database, use either export/import to move data between machines or use SQL to retrieve and transform existing data and load it into the application tables.
See Also:
"Loading Demonstration Data" and "Importing, Exporting, Loading, and Unloading Data" in Oracle Database Express Edition 2 Day DBAWhen the application login page calls the login API with a user name and password, the Application Express engine calls the credentials verification method specified in the application's current authentication scheme. You have three choices as to how credentials are verified from within the login API:
Implement the method yourself as a PL/SQL function returning Boolean and put it in your application's schema.
Use the built-in LDAP authentication method, which checks user name and password against the LDAP directory that you specify.
Use the built-in Oracle Application Express authentication method, which checks the user name and password against the Oracle Application Express workspace repository.
Your application is currently using the built-in Oracle Application Express authentication method.
See Also:
"Establishing User Identity Through Authentication" in Oracle Database Application Express User's GuideSee Also:
Security How To documents on OTN:http://www.oracle.com/technology/products/database/application_express/howtos/howtos.html
In order for your application to be accessible, you need to create users. If you are still using Oracle Application Express authentication, the simplest way to create users it to access the Manage Users page.
To create a new user:
Go to the Workspace home page.
From the Administration list on the right side of the page, click Manage Application Express Users.
From the Tasks list on the right side of the page, click Create End User.
Under User Identification, enter the required information.
Click Create User or Create and Create Another.
Now that you have deployed your application, loaded data, and created users, you can publish your production URL.
You can determine the URL to your application by positioning the mouse over the Run icon on the Application home page. The URL appears in the status bar at the bottom of the page.
The Run icon gets its value from the Home link attribute on the Edit Security Attributes page. This link is only referenced by this icon and by applications that do not use the Application Express Login API. Consider the following example:
http://apex.oracle.com/pls/otn/f?p=11563:1:3397731373043366363
Where:
apex.oracle.com
is the URL of the server
pls
is the indicator to use the mod_plsql
cartridge
otn
is the data access descriptor (DAD) name
f?p=
is a prefix used by Oracle Application Express
11563
is the application being called
1
is the page within the application to be displayed
3397731373043366363
is the session number
To run this example application, you would use the URL:
When users log in, they receive a unique session number.
As you may recall, you created the Issue Tracker application using the Create Application wizard. This wizard creates a process on the Login page (page 101) that controls authentication. The contents of the process are:
WWV_FLOW_CUSTOM_AUTH_STD.LOGIN( P_UNAME => :P101_USERNAME, P_PASSWORD => :P101_PASSWORD, P_SESSION_ID => :FLOW_SESSION, P_FLOW_PAGE => :APP_ID||':1' );
Note that the Page is hard coded into this process. Because of this, the page you pass in to the URL is overwritten and does not need to be included. You can access the application by using the following URL:
As you can see from the example used, the URL has no meaning and can be rather long. The host name can be changed to make it more symbolic. You can also configure Apache to rewrite your URL so that you can publish an abbreviated format and a URL that would be more intuitive to your users. See your Apache documentation for details.
