Siebel Business Process Framework: Workflow Guide > Building a Workflow Process > Process of Building a Workflow Process >
Defining Step Properties for a Workflow Process
This task is a step in Process of Building a Workflow Process. A workflow step's properties can include input and output arguments, search specifications, operations, and so forth. You can define some of these properties by using the WF Steps OBLE. You can also use the Properties window and the MVPW from within the Process Designer to define the step's properties. In any case, a step's properties must be defined one step at a time. To define step properties
- With the Process Designer open, click the step whose properties are to be defined.
- Use the Properties window to define the step's basic properties.
If the Properties window is not displayed, right-click then choose View Properties Window. For more information, see About Workflow Process Steps and Connectors.
- Use the MVPW to define input arguments, output arguments, and search specifications.
For more information, see About the Multi Value Property Window.
