Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties > About the Workflow Process Object Hierarchy > About Object PropertiesWhen the Workflow Process object type is chosen in the OE, the right pane displays the Workflow Processes Object List Editor (OBLE) that contains a list of workflow processes currently defined in the srf. One row in the OBLE represents one object definition. For example, values in the properties in the workflow process named Contact-New Order constitute one object definition. Properties of the object definition can be edited in the OBLE. Object properties are represented as columns in the Object List Editor window. Information entered in the columns of an OBLE window is values. You edit properties of the currently chosen object definition in an OBLE window by changing values in the columns. You can change the property values in an object definition. You cannot change the set of properties that constitute an object definition. You can also use the Properties window to edit the properties of the currently chosen object definition. Changing a property value in the Properties window also changes the corresponding value of that property in the Object List Editor window, and conversely. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
