Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > About Cursor Close >
Modifying the Cursor Close Alert Message
You can modify the message that is displayed to the user when there are more rows than can be returned in a query. To modify the cursor close alert message
- In your Siebel application, navigate to Site Map > Administration-Application > System Preferences.
The System Preferences view appears.
- In the System Preference Name column, select the SSASqlErrRsltsDiscarded parameter.
- Edit the value in the System Preference Value column to how you want the cursor close alert message to display.
The maximum message length is 200 characters.
- Restart the Siebel application.
