Siebel Product Administration Guide > Products with Attributes > About Managing Attribute Definition Records >
Viewing Related Objects for Attribution Definitions
The Attribute Definition Cross References view allows you to view the objects that are related to an attribute definition, including:
- Class. Product classes that contain the Attribute Definition
- Smart Part Number. Smart Part Numbering that makes use of the Attribute Definition
To view related objects for an attribute definition
- Navigate to the Administration - Product screen, and then the Attribute Definitions view.
- In the Attribute Definitions list, select the definition whose related objects you want to view.
- In the Versions list, click the version whose related objects you want to view.
- Click the Cross References view tab.
- In the Cross References link bar, click the Class or Smart Part Number link to view lists of related objects.
