Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > EnumObjects MethodThis method returns either all immediate objects under an object or all immediate objects under a specified port. This gets the items that are currently in the port, not the items that could be there. Input Arguments
Output ArgumentsOutput can be in the form of two types of property sets, instance property sets and generic property sets. Instance property sets return information about child items, as follows: < Name="value" Product Id="value" Path="value" Sequence Number="value" /> Generic property sets send notifications to the user that there is a violation of the minimum or maximum required quantity for a one or more items within the relationship. A generic property set follows each instance property set, if there is a violation of the minimum or maximum required quantity for this instance. |
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
