Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
SyncInstance Method
This method saves the complex object instance where it originated. Input Arguments
- ObjId. The unique identifier of the complex object header.
- RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
- IntObjName. The name of the integration object specified in Oracle's Siebel Tools.
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
None
