Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces >
Process of Creating a Custom Siebel Configurator User Interface
To create a custom Siebel Configurator user interface, perform the following tasks:
CAUTION: In the Customizable Product UI layer, the type of the user interface controls must match with the type of the user interface option and the base theme type of the user interface option. If they do not match, the user interface will be rendered incorrectly or there will be runtime errors. For example if you select a Customizable Product menu base theme, then you should only select relationship or attributes controls for menu theme. As another example, if you select a customizable product base theme of type High Interactivity, then you should only select High Interactivity relationship or attributes UI controls. As another example, you should not mix High Interactivity and Standard Interactivity user interface themes, and should not mix menu and non-menu themes.
