Name |
Enter the name of the link. Use this name to refer to the link when you write constraints. This field is required. |
BusObj Name |
For context variable links, leave this field blank. This field is used for business component links. For more information, see Creating a Business Component Configuration Link. |
BusComp Name |
BusComp Field Name |
Expression |
Displays an XML expression that is automatically generated by your entries in the other fields. |
Needs Execution |
Select this check box to retrieve the link information from a new instance of the business component. Deselect it to retrieve information about the current instance of the business component. |
Search Spec |
Sort Spec |
Default Value |
Enter the value that you want to assign to the link if the evaluation returns no value. Please note that you can also specify a default value in the variable map definition. This default has precedence over the default defined here. |
Keyword |
To create a context variable link, choose Context Variable. |
Context Variable |
To create a context variable link, enter the name of the variable in this field. The variable must be in the variable map that is currently being used. |
Context Variable Type |
To create a context variable link, enter the variable type in this field. |
Description |
Enter a description of what the link does. This description is not displayed to customers. |
