Siebel Product Administration Guide > Configuration Constraints > Activating and Deactivating Configuration ConstraintsWhen you create a constraint, it may be active or inactive by default:
An active constraint is used to compute all solutions (if the date is within the start and end date of the constraint). When you deactivate a constraint, it is not used to compute solutions. One reason for deactivating a constraint is to help you test constraints in Validate mode. You can deactivate a group of constraints and then activate them one at a time to see how each affects the product's behavior when it is being configured. Another reason to deactivate constraints, is when you want to release a version of a product that does not require a constraint to be active. You can deactivate the constraint and then release the product. The constraint is inactive in the released version and is not used to compute solutions.
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
