Siebel Product Administration Guide > Configuration Constraint Template Reference > Procedural Condition Templates > Procedural-Condition Check TemplateThe Procedural-Condition Check template has the form: If procedural condition [item or condition] is true, enforce resultant condition item or condition You use the Procedural-Condition Check template to check for a precondition. If the item or condition it checks for is true, then the resultant condition is enforced in the solution. If condition 1 is satisfied before the user clicks, condition2 must be satisfied after the user clicks. Otherwise, an undo only conflict error message is generated. During LoadInstance, this rule is not enforced, because no precondition is satisfied. |
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
