Siebel Product Administration Guide > Configuration Constraint Template Reference > Simple Provide and Consume TemplatesThe Simple Provide template has the form: Provides [a value] to [a target] The Simple Consume template has the form: Consume [a value] from [a target] The Simple Provide and Simple Consume templates positively or negatively increment the amount of the target operand. These templates are intended for use as the action portion of a conditional constraint. If the condition is true, then a value is provided or consumed from the specified target. The Simple Provide template contributes a positive amount, that is it increases the amount of the target. The Simple Consume template contributes a negative amount, that is it reduces the amount of the target. ValueThe value operand defines the quantity to be contributed to the target. The Constraints view provides several methods for determining this quantity:
TargetThe target operand is incremented by the amount specified in the value operand. The target can be a product, resource, or product attribute. It cannot be a relationship, a class, or an expression. Product TargetWhen the target operand is a product, the quantity of the product is incremented in the solution. Resource TargetWhen the target is a resource, the value of the resource is incremented. Attribute TargetWhen the target is an attribute, the value of the attribute is incremented. Attribute targets are similar in behavior and use as resource targets. There are several restrictions on using provide and consume constraints to manipulate attribute values:
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
