Siebel Security Guide > Communications and Data Encryption > Configuring Encryption for Mobile Web Client SynchronizationThis topic describes how to enable encryption for Mobile Web Client synchronization. During this synchronization, DX files are transferred between the Siebel Server and Mobile Web Clients. DX files use SISNAPI messages to transfer information between the Siebel Server and Mobile Web Clients. This task is a step in Process of Configuring Secure Communications. The Siebel Mobile Web Client reads configuration parameters in the Siebel application configuration file (for example siebel.cfg, used by Siebel Sales) to determine the type of encryption to use during synchronization. Encryption options are defined as one of the elements in the DockConnString parameter. NOTE: Secure Sockets Layer (SSL) is not a supported encryption method for the Siebel Developer Web Client or for synchronization of the local database on the Siebel Mobile Web Client. For information about authentication for Siebel Mobile Web Client and Siebel Remote, see Authentication for Mobile Web Client Synchronization. For information about other security issues for Siebel Mobile Web Client, including encrypting the local database, see Siebel Remote and Replication Manager Administration Guide. To enable encryption of synchronization on the Mobile Web Client
| Siebel Security Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
