Siebel Security Guide > Communications and Data Encryption > Security Considerations for Unicode SupportSiebel Business Applications support Unicode. For comprehensive Unicode compliance, consider the following encryption and authentication issues. Using Non-ASCII Characters in a Unicode Environment
Logging Into Siebel Business Applications
Encrypted DataSiebel Business Applications provide either AES and RC2 encryption to encrypt data for sensitive information such as credit card numbers. For encryption with Unicode, you must use either AES or RC2 encryption, rather than the Standard Encryptor, which is no longer supported. For more information, see About Data Encryption. |
| Siebel Security Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
