Siebel Database Upgrade Guide for DB2 UDB for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks > Starting the Siebel Upgrade Wizard >
Restarting the Siebel Upgrade Wizard After Pauses
Use this procedure to restart the Upgrade Wizard after it has paused to allow you to apply files generated on the midtier to the z/OS host. To restart the Upgrade Wizard
- Navigate to the
SIEBEL_ROOT\bin directory (Windows) or the $SIEBEL_ROOT/bin directory (UNIX).
- Do the following:
- Windows: Double-click on the upg_restart.bat file
- UNIX: Run upg_restart.ksh
