Siebel Database Upgrade Guide for DB2 UDB for z/OS > Postupgrade Tasks for a Siebel Development Environment > Regenerating the Database Template FileEnvironments: Development environment only. Following the upgrade, you must regenerate the SQL Anywhere template database file used by Siebel Remote. This process updates its schema to the same version as the Siebel Database Configuration Utilities. You will use the Generate New Database component from a new Siebel Server to do this. For procedures on regenerating the SQL Anywhere Template file, refer to Siebel Remote and Replication Manager Administration Guide. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
