Siebel Database Upgrade Guide for DB2 UDB for z/OS > Generating the Siebel Upgrade Files > Preparing and Executing the Non-Additive Schema and JCL Files on the z/OS Host > Applying the Non-Additive Schema ChangesPerform the following procedure to apply the non-additive schema changes to the staging database. If you are performing a development database upgrade, or if you are performing a production database upgrade but chose not to apply any additive changes in advance, all the Siebel 8.0 schema upgrade changes are now applied to the staging database. To apply non-additive schema changes
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
