Siebel Database Upgrade Guide for DB2 UDB for z/OS > Migrating Siebel 6.2.1 Customizations > Running the Web Layout WizardEnvironments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. If some views or applets did not migrate properly when you ran the Siebel Web Client Migration Wizard to upgrade to Release 8.0, you can remigrate them using the Web Layout Wizard. With the Web Layout Wizard you can migrate applets or views individually or in groups. When you select applets for migration, they must be in the same base class. When you select views, they must be of the same type. You can run the Web Layout Wizard on applets and views multiple times. For more information on migrating created or modified applets and views to the Siebel Web Client, see About Migrating to the Siebel Web Client.
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
